Eagle 50 factory 4 in 1 settings RX-603
OR
I have a question. I have messed with the pot adjustments, both delay and limit on my exceed eagle 50's 4 in 1 unit. Now I have issues with the tail motor turning on and off and on again with about .7 second intervals. Its not exactly wagging, and its not really holding a heading either. The tail motor used to spin at a consistent and constant speed before I went messing with things but I have always had to "fly the tail" so to speak
Does anyone know what the factory settings are for the RX-603 settings are? the delay pot has a range of 0-100 but the limit has 0-120. What is a good starting point to work from? And does a clockwise turn of the pot increase these values? What might I do to correct the on-off-on-off issue with the tail motor?
Thanks!
Thanks!
Try this. When motor is going in and out that means your gain is set too much. I find the gain is best when it's turned right, Max, all the way and then 1/4 to 1/2 turn back left.
Andy
Andy
