springs and shock oil question about mmgt
Have any of you switched from the blue springs? or changed the shock oil? What are your suggestions?
I think the blue springs are a little soft, but I am not sure. Is there a way to test if you need to stiffin up the springs or not? I think my MMGT bottoms out a lot on landings.
RE: springs and shock oil question about mmgt
On the MGT 8.0 it makes a big difference, and improvement, if you switch 4 of the stock blue springs to red ones and leave 4 of the springs blue. I can only assume it would make a similar improvement to the MMGT, but I've never seen it done. Also, a little bit heavier shock oil, 40-50wt., will probably help you out too.
AL
