Dumas Scarab
Dumas Scarab
Old 04-21-2009, 11:09 PM
Lil Dave
Default Dumas Scarab
Hey Guys! I'm Lil Dave. Can you help me Identify? I know Dumas, I think scarab. I've been looking at ur forums all day and you guys are more experienced than I and would like your help to do A quality build. I got hull, 25cc homelite, and outdrive for CHEAP! I got my birch ply today and hope to get to making parts tonight. Thanks for looking!
ID:	1184994   Click image for larger version
ID:	1184995   Click image for larger version
Old 04-22-2009, 12:21 AM
Lil Dave
Default RE: Dumas Scarab
Ok, So what Are the thoughts on mounting my outdrive? I like the idea of surface mount. Pros? cons? any mods That can be done to the little homelite internally? and finally cooling? I'm not going to run a clutch. wet liner?
Old 04-22-2009, 09:55 AM
melvenraymie
Mount your set up about 1/2 inch up and 1/8 -1/4 inch to right. Use 10/32 stainless blind nuts and 10/32 by 3/4 inch stainless allen bolts and you should be running straight turn like you want it to.
Old 04-22-2009, 12:42 PM
Lil Dave
Up and over huh? is that due to a flaw in the mold? I'm looking at mounting the engine, whats the best method at figuring position for best performance and handling?
Old 04-22-2009, 03:16 PM
skoda450
I started out with a setup much like what you have there. Set the outdrive up for surface drive. That is when the boat is on plane, ~1/2 the prop is in the water. This means that the prop shaft exits the hull right at the bottom of the "V" in the transom, not under the hull. Since you are using an air cooled engine, keep it that way. The trouble of converting it to water cooling is not worth the effort. It can be done but no gains are realized on a Homelite conversion.
BTW keep the flex shaft from the trimmer if tyou still have it. The prop shaft looks to be 1/4" so adapters are readily available form parts houses to make the connection from the flex to the prop shaft. The bonus is that the square end of the flex shaft is the way it originally connected to the engine in the trimmer. Just create the stuffing tube to contain the flex from K&S brass tubing stock and your there! Check out radio boxes for your electronics from the same parts houses. I like the ones at http://www.eellspdx.com/ they work wellin deep Vee hulls, are quality and inexpensive.
Check out Marine Specialties http://www.marinespecialties-rc.com/hullprice.htm for other goodies like the adapters..
Good Luck...
Old 04-22-2009, 04:24 PM
martno1fan
martno1fan's Avatar
Dave before you fix the motor in position place things in the boat where they will be going such as tank radio gear etc and hang the hardware on the back even if you just tape it in place for now then balance the boat on a broom 28- 30% from the transom,use the motor to find the balance point then mark for mounting that way your boat should be well balanced for best performance.As was said for surface drive exit transom 3/8" up from the vee to centre of hole for tube and 1/4" to right of centre to overcome prop walk which monos suffer from.Leave it air cooled and run as is,it will get plenty of air to cool the motor but leave the shroud on to help direct the air where its needed.You can mod the motor,a bit of simple porting will wake it up if needed but id run it as is first.Also a tuned pipe will add to its performance.
Mart
Old 04-22-2009, 11:25 PM
Lil Dave
So Here is some progress pics. I measured the stringers at 5" apart, I made a reinforcement for the transom, and a second to make a compartment for the electronics. the reason for the crossmembers is i have to do things above required cuz I'm like that. I'm building the stringers and a web for the front out of the plywood i have left, I couldn't decide on stringer length so I'm doing the whole thing. I doubled them up because I have no idea what engine this may end up with once I get over the homelite. Once the construction on the support structure is complete I will glass into place and decide on a floatation material.
Old 04-22-2009, 11:30 PM
Lil Dave
I like it
ID:	1185595   Click image for larger version
ID:	1185596   Click image for larger version
ID:	1185597   Click image for larger version
Old 04-22-2009, 11:31 PM
Lil Dave
So I'm finishing up my stringers now. I am having a hard time with mounting my outdrive up and over and not dead center. I understand why but I think it will look funny, can someone show a pic or two of how theirs have come out? Keep the tips coming boys, I appreciate them
Old 04-27-2009, 04:37 PM
skoda450
I never had an issue with propwalk with the prop centered on the transom. The V is sufficient to hold position and the Homlite is not going to develop enough power to lift the boat and allow prop walk. K.I.S.S. and put it in the middle of the hull and close to the bottom to keep 1/2 the shaft in the water. Save your money and effort on engine mods until you move up to a Zenoah. Then add a pipe and porting mods to wake it up.
You can add some performance to the Homelite by opening up the stock muffler and gutting the baffels, stuffing the crankcase by adding to the thickness to the rear crankcase cover with 1/8" aluminum plate or using a very thin gasket between the cylinder and the crankcase to increase compression. The latter is sometimes a wash because lowering the cylinder also retards the intake port timing. These are old tricks but they are still valid today.
Old 04-28-2009, 11:37 PM
Lil Dave
Cool. I finished my engine mount, since I am doing this on a really tight budget I made everything myself. as of now I'm into this whole project 130 bucks.. heh! So i'm saving for a nicer engine. In the process of glassing now and will post pics soon. My other boat is nitro and kinda finicky so I just want the homelite to be reliable and fun to play with until I get my hands on a zen. Is there any minimum distance from prop to transom?? My outdrive gives me an 1.250 distance. I was thinking of building a extension? Whatcha think?
Old 05-03-2009, 05:23 PM
Lil Dave
Heres a few new pics. I thing I got the center of gravity good. Nice and low and About 30%. Waiting on some parts now. and have to finish glassing.
ID:	1191437   Click image for larger version
ID:	1191438   Click image for larger version
ID:	1191439   Click image for larger version
Old 05-03-2009, 09:12 PM
darindotson
Nice build!!! But I don't believe that's a Dumas Scarab 38kv. That boat has a center spine running right down the top of the boat. Also, the cockpit area is squared off, not rounded like yours.
Beautiful job!!
Darin
Old 05-03-2009, 09:44 PM
Nosedragger
Its a Dumas 38 Scarab
http://www.udisco.com/hobbies/pics/016032.jpg
Dumas made a few type of Scarabs. The Scarab 38 KV is the squared off version.
Old 05-03-2009, 09:48 PM
darindotson
Gotcha! I have the Dumas 48 inch, and didn't realize they made another besides the 55. Thanks! I did note the "A Dumas Boat" badge in the interior..
Old 05-03-2009, 10:10 PM
Nosedragger
I have an original color catalog from Dumas with those boats, always wanted both of them.
Old 05-03-2009, 11:07 PM
Lil Dave
YEs! Thats exactly what I wanted. That is the first pic I have seen of a hull the same as mine! Any Chance of posting a few pics from the catalog? I'll be posting more pics soon. Thanks for looking! Keep the comments and suggestions coming!
Old 05-04-2009, 12:26 AM
Nosedragger
Well theres this picture
http://www.happyhobby.com/hobb_html/.../dumas1440.JPG
I'll look for the catalog, it may take a while to find it.
Old 05-04-2009, 12:46 AM
bullboy8
bullboy8's Avatar
Hey Dave it was good talking to you today! Didn't realize I got someone that's soo close to me with the same addiction We will deff have to get together to run some time. Build is looking great by the way! -Edmond
Old 05-04-2009, 01:29 AM
Lil Dave
No worries Nd. Thanks for the pics. Darin, Have some pics of ur scarab? And Ed, I have ur number in my phone and I will be in touch. Feel free to call me and we'll go out for some hot laps! Tempe town lake!! lol
Old 05-04-2009, 07:54 AM
darindotson
Dave- I have some pics in my other thread, regarding a new motor in a Scarab 60- have a look!!
Darin
Old 05-04-2009, 11:09 AM
Tidnab
My Feedback: (51)
Tidnab's Avatar
Expresscraft also makes a Scarab with the rounded hatch area http://www.expresscraft.com/scarab.htm
Old 05-04-2009, 04:14 PM
FlogginHarvey
Hey, ND.
If you can dig up that old Dumas catalogue I would love to have a digital copy of it! If it is too much of a PITA another Scarab owner mailed me a copy of the original 38KV build plans, I scanned them and shot them back with a thumb drive hiding a set of digital copies of the plans. If you do not have the time to scan and don't mind lending the literature...I will do the same?
Pop me line at [email protected] if you are interested...
Old 05-04-2009, 05:55 PM
Nosedragger
I have to find it first! Its in with about 30 years of rc boat,car,airplane magazines, plans, catalogs etc. Its good thing this rc hobby is only a passing interest...
Old 05-07-2009, 11:14 PM
Lil Dave
Heres a few new pics. I took My nitro Sk Daddle too out for it's first voyage today. It was ok, I lost a rudder due to a poor solder. I like muh gassers best. I may convert it to electric and use it to pull a floating line out for retrieval purposes. My stuffing tube on the scarab is stainless, so Is the hardware, I made all the braces from aluminum since I have more mechanical aptitude than money. Oh well I like being creative. I'm waiting on my radio box and outdrive standoff still before I can finish my glassing. The black is a 2 part epoxy which will be glassed over and likely painted. I'm still gonna put in the bulkhead behind the front tube mount I just need to make sure my rad box fits. Thanks for looking!!
ID:	1194317   Click image for larger version
ID:	1194318   Click image for larger version
ID:	1194319   Click image for larger version
ID:	1194320   Click image for larger version
ID:	1194321   Click image for larger version
ID:	1194322   Click image for larger version
