Tap and Drill set?
RCU Forum Manager/Admin
My Feedback: (9)
RE: Tap and Drill set?
As Minnflyer said above, either one will be good for most everything we are going to do. I use a set that I picked up from Harbor Freight. I wouldn't do machinist level work with them, but for what I do on my planes they are more than enough.
Ken
Ken
WA
You are not cutting steel, you are cutting at worst, aluminum or fiber reinforced engine mount, often just balsa or balsa hardened with CA, . Either set will be fine. While it's not great, I've been using a HF set for about 10+ years and it's held up on steel.
Jack
Jack
MI
like said before , most any of the sets will work for our stuff. Its nice to get the tap and drill set together, makes things easier. Sears sells some very good sets. thats what I bought when I was working in a machine shop.
If you taping aluminum or any metal, be sure to use tap oil. Your taps will last longer and you will cut a better thread. Aluminum seems to be the worse for loading up tooling, I would use a good amount of oil with taping it.
When taping its a good idea to back the tap out of the metal once in awhile and clean the tap. Taps can and will break at the worst time, I know I have broke more than my share.
sticks
sticks
