OIL?
IL
OIL?
What oil are you guys running? I've used Klotz (kl200) pure synthetic,Amzoil,synthetic,ect. I tore my engine down after running the Klotz (100% pure synthetic) and the piston/combustion chamber was spotless! The problem I have is the oil isn't available locally,but Klotz (kl 100) is. It's part (80% synthetic) and (20% benoil/caster).would the syn/caster blend run alright in my zenoah motors? Any advice is appreciated. Ron
NB, CANADA
RE: OIL?
RKS,
after checking on another site that a fair number of us also belongs too,
it seems that a fair number have tried the klotz 100 (Benol/Castor) and it looks like the consensus is that although it does work, the benol/Castor seems to leave a fair amount of carbon and it gum's up the carbs after sitting.
if you don't like carbon or carb gumming up klotz 200 or any good synthetic oil will do.
Dan.
Dan.
RE: OIL?
i beleive castor is old school...i have run aero on klotz and coolpower blue for years and NOT any problems...in my gas engines i use shell vsx 2 stroke full synthetic....bob
RE: OIL?
i have been using castrol 747 which is also a synthetic/castor blend and its fine, no carbon buildup, no gumming up carbs, and it smells real good when it burns
RE: OIL?
Ive been using Torco GP 7 racing oil been great very clean almost no smoke at all bit expensive but but hey i got a few bottles for free to try from a mate
RE: OIL?
Another A747 user here. I use it in the Zenoahs.
For the Hi Rev QD I have used Redline...............seems alright, but I finally found a supplier of HP-2 so I am going to give that a crack
Johno
Johno
RE: OIL?
Currently running Klotz, I have run Amzoil, and the Quick sliver mercury oil has worked good in the past. Like the smell of Klotz. Everyone will have there farvorites, but if you run a good quality 2stroke oil you should be fine. What was it that you said you were able to get local. You might just ask about what you are using.
Take care;
Randy
Take care;
Randy
RE: OIL?
Valvoline synpower 2T fully synthetic,ive used this for two years on my stock and full mod zenoahs.Seems good and i sold my stock zenoah to a forum member and the cylinder and piston were like new he said after stripping her down,i recently checked the full mod and its also like new so im sticking with this oil.
Mart
Mart
LA
RE: OIL?
ORIGINAL: RKS1949
I think the caster oil is for nitro. I was told that in the nitro form one time before when i asked adout some oil to put in nitro fuel.
IL
RE: OIL?
Thanks,guy's! We can get the KL100 20% castor locally,but if it gums up the carb,we might just go with the Quick Silver. Was the Mercury Quick Silver conventional oil,or the synthetic blend? Might check and see if we can get the Castrol747 too,at NAPA. Ron
RE: OIL?
ORIGINAL: jacob711
Daniel
Edit: I was wrong the Maxima is castor 927. It is a blend and offers great protection without a lot of carbon buildup. I used the Honda HP2 and it made lots of carbon.
Redline high RPM Kart oil is good stuff also. Didn't think that much of any of the Amsoil products but the Saber is better for us than the Dominator. Plenty
people using it successfully though.
http://www.maximausa.com/products/2stroke/castor927.asp
RE: OIL?
[quote]ORIGINAL: danielplace
ORIGINAL: jacob711
Catrol does make A747 (at least here in Australia). Maxima Castor 747 is a different animal. Some guys I know of have also used Maxima with good results from all accounts
AL
RE: OIL?
Ive been running klotz kl 100 for quite some time now with no guming or any problems 8 oz to the gal runs great provides plenty of protection and smells good I think that a good oil and at least 8 oz to the gallon is more forgiving if you happen to lean it out a little just my thoughts
OK
RE: OIL?
The Quicksilver I'm using at the moment is just the regular Quicksilver Premium outboard oil, TC-W3 certified it says on the bottle. I actually thought I had the synthetic, but it runs great so far. Nice blue-green color, low smoke, if any.
T-Daddy
T-Daddy
RE: OIL?
For many years I have been using Amsoil Dominator at 40:1 in all of my gassers. Amsoil produces a lot of black mess out of the exhaust and carbon in the combustion chamber. About 6 months ago I started using Quicksilver at 40:1. The black mess is virtually gone and the engines run fine on it.
Academy Sports and Outdoors carries it.
