TigerMoth Racing LCG V10
<div style="margin: 0in 0in 0pt">Introducing the TigerMoth Racing LCG V10, The newest entry into the highly competitive world of 1/10th scale touring car racing.It brings with it the innovation to break free from the pack with progressive features like the ability to switch from upright to laydown suspension geometry and fully ball jointed arms for unlimited adjustment opportunities.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt" align="center"><span style="font-size: 18pt">LCG V10 Features List</span></div><div style="margin: 0in 0in 0pt" align="center"></div><div style="margin: 0in 0in 0pt"><u>Innovative Features:</u></div><div style="margin: 0in 0in 0pt">-Swappable between upright and lay down shock configuration,</div><div style="margin: 0in 0in 0pt">-Replaceable droop screw plates save chassis wear,</div><div style="margin: 0in 0in 0pt">-High strength extra wide nylon front bumper protects arms and shocks in impact,</div><div style="margin: 0in 0in 0pt">-Fully ball jointed suspension arms for unlimited adjustment capability,</div><div style="margin: 0in 0in 0pt">-All usual adjustments; castor, camber, toe, droop, ride height all adjustable with no additional parts,</div><div style="margin: 0in 0in 0pt">-Hollow aluminum axles,</div><div style="margin: 0in 0in 0pt">-Styrene core carbon fiber chassis, steering base plate, steering arm and upright shock towers,</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><u>Chassis:</u></div><div style="margin: 0in 0in 0pt">-Super lightweight simple battery retainer,</div><div style="margin: 0in 0in 0pt">-Single deck 4.5mm laminated rigid carbon fiber and styrene chassis plate gives super low center of gravity and light weight,</div><div style="margin: 0in 0in 0pt">-Central inline motor, battery and servo for great weight transfer in cornering.</div><div style="margin: 0in 0in 0pt">- Pocket style battery tray accepts new lithium as well as traditional NIMH batteries.</div><div style="margin: 0in 0in 0pt">-Recessed motor and servo for low center of gravity,</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><u>Driveline:</u></div><div style="margin: 0in 0in 0pt">-Lightweight hollow center shaft in sliding mounts allow adjustment of belt tension,</div><div style="margin: 0in 0in 0pt">-Large 10 x 15mm diff bearings,</div><div style="margin: 0in 0in 0pt">-MIP steel outer axles,</div><div style="margin: 0in 0in 0pt">-Efficient 2 belt drive train with lightweight wide ball differentials,</div><div style="margin: 0in 0in 0pt">-All axle pins have flats for positive setscrew fastening,</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><u>Suspension:</u></div><div style="margin: 0in 0in 0pt">-High performance Ultralloy plastics,</div><div style="margin: 0in 0in 0pt">-upper and lower suspension arms provide rigidity and reliably hold settings,</div><div style="margin: 0in 0in 0pt">-Lower arms are 7075 aluminum with 3mm steel screws into ball joints.</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><u>Performance:</u></div><div style="margin: 0in 0in 0pt">-47 specially CNC machined 7075 anodized aluminum parts,</div><div style="margin: 0in 0in 0pt">-Full ball bearings included,</div><div style="margin: 0in 0in 0pt">-Standard 3 and 4mm hardware,</div><div style="margin: 0in 0in 0pt">-Adjustable Ackerman single arm steering rack,</div><div style="margin: 0in 0in 0pt">-Delrin axle blades for long life and low driveline drag,</div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt" align="center">![](http://tigermothracing.com/images/DSCN7047a.jpg?435)
![](http://tigermothracing.com/images/DSCN7007i.jpg?435)
![](http://tigermothracing.com/images/DSCN7002k.jpg?435)
<div style="margin: 0in 0in 0pt" align="center">Go to www.TigerMothRacing.com today to check out all the latest news and products.</div><div style="margin: 0in 0in 0pt" align="center"></div><div style="margin: 0in 0in 0pt" align="center">Make sure to check us out on Facebook!!!!</div><div style="margin: 0in 0in 0pt" align="center"></div><div style="margin: 0in 0in 0pt" align="center">And always feel free to contact us ether via this forum or the e-mail on the website.</div></div>
