Castle 9000
AB, CANADA
In series or parallel? Parallel is no issue, you're just increasing the capacity. Series is another matter and will depend on whether the motor and esc can handle 14.8v.
Moderator
2s is the max voltage you'd want to feed a Castle 9000. So, 2 2s batteries would only work if used in parallel for more run time, series would be way too much voltage.
