t maxx glow plugs
Old 06-25-2009, 09:14 PM
rcslsafut
rcslsafut's Avatar
Default t maxx glow plugs
any one have problems with glow plug failure i cant keep my t maxx running unless the glow charger is on it replace the glow plug good to go for a few more tanks then back to the same problem been running os #3 glow plug that what lhs recomend have tryed mccoy to is my tune way off havent temp gun it but if i set it any where far from where it is tuned it doesnt sound or run right oh and if i have not mentioned it yet it is pro .15 old t maxx pretty sure it nots wore out but who knows have not tore it down to see any info would be appreciated
Old 06-25-2009, 11:12 PM
StemTMAXX
Default RE: t maxx glow plugs
what traxxas plugs are you using?
Old 06-26-2009, 02:55 PM
larryf333
larryf333's Avatar
The pro .15 has alot of heat issues. Even Traxxas will admit to that. You are probably frying your glow plugs with the tune.
I'd check everything for leaks, seal it up, then re-tune. Glow plugs should never go out that often.
Old 06-26-2009, 04:36 PM
StemTMAXX
i've had the same glow plug in my 3.3 since fall of last year. I run 3232's
Old 06-26-2009, 09:20 PM
rcslsafut
rcslsafut's Avatar
thanks for the info
i have noticed the darn thing always seems hot have read a least ten tuning guides not sure i still got it right
the thing seems to take off right run through a whole tank and doesn sound weird but i will be the first to tell you im a novice when it comes to nitro
Old 07-01-2009, 04:06 PM
moe7404
moe in wichita ks i have a t-maxx 3.3 i burned up 3-4 plugs in less than 1 gal of fuel. i switched to 30% and richened it up with a #3 plug , planing on going to a #8. with the hot plug dont be afraid to go rich. years ago when my dad and i drag raced the 1/4 mile, 392 hemis, 440s, my dad would say "its better to foul out a plug cause its cold or rich than burn a hole in a piston cause you have to hot of plug" it seems to me on a 3.3 it takes a LOT of run time before you see any color in the plug, so go more by heat of engine and how it runs.
Old 07-01-2009, 06:38 PM
jbrown_101
rcslsafut,
I have the same exact problem that you have. I don't know why but every couple of tanks I'm fowling out a plug and it really pisses me off when they get fowled cause I can't run till I get a new one and there kinda expensive. I have a new 3.3 with probably 3/4 of a gallon throgb it. Anybody have some advice??
Old 07-01-2009, 09:15 PM
nargargle
I had very bad luck with the Traxxas plugs.  I swiched to a McCoy MC-59 and will never go back to the stock plugs.  They just didn't last.</p>
Old 07-01-2009, 10:06 PM
rcslsafut
rcslsafut's Avatar
i got a mccoy mc-59 couldnt take off the glow plug charger or the engine would die . but im not knock them i know a lot of poeple have good luck with them think i just got a bad one right out the box . called the lhs they said they would gladly replace it but they are 35 miles away not going that far for just a glow plug . thanks for the input !!!!!!
