Fusion Knife edge coupling issue
ON, CANADA
Hi Everyone,
I have the 52" (?) Fusion profile. In KE, it couples to the canopy very strongly...is this normal and should I just mix it out? Motor is OS 46AX, 12x5 apc prop.
Ray, BRCM
Oakville Ont.
Ray, BRCM
Oakville Ont.
RE: Fusion Knife edge coupling issue
ORIGINAL: Raysun
Hi Everyone,
I have the 52'' (?) Fusion profile. In KE, it couples to the canopy very strongly...is this normal and should I just mix it out? Motor is OS 46AX, 12x5 apc prop.
Ray, BRCM
Oakville Ont.
Hi Everyone,
Ray, BRCM
Oakville Ont.
ON, CANADA
Thanks, I do carry some up ele, where should CG be? In inverted, ineed a fair bit of push stick, so I'm likely nose heavy.
Ray
Ray
ORIGINAL: Raysun
Ray
Ray
