Slicks
RI
What are the advantages to them i run mainly street IE: pavement , concrete I'm not a racer or dragster i like running laps and doing power slides "drifting" so if i used slicks would it take longer to hook up traction wise and would they be any good for me? or would it make for some interesting slides?
I have no first hand experience with slicks so any help you can give me would be great.
http://cgi.ebay.com.au/ws/eBayISAPI....m=220439898124 this guy sells overseas pretty cheap - hes a good mate of mine... these tyres are definatly the best for what you want.message him and hele send you a quote
RI
Well I'm not looking to buy I'm trying to find out just what slicks do.
Do they add more traction or less since they have no pattern to the rubber ?
Would i slide more in corners if i ran slicks or would i grip the corner and not slide or spin out ?
Whats the difference in drift tires as apposed to slicks ?
Besides all these drift tires seem to small for a evader.
ORIGINAL: nitrocomplex1776
No pattern on rubber means more surface contact = more grip. (only on dry surfaces tho) You can still spin out tho depending on how you control your throttle.
Drift tires are hard rubber/plastic, slicks are soft rubber compound.
Slicks heat up and stick better for racing just like the F1 cars when they warm up the tyres.
Like said above drift tyres are a harder compound so slip on contact losing traction causing big drifts
