Rich or lean? I'm really confused O.o
Old 06-30-2009, 09:04 PM
Xtfreak
Xtfreak's Avatar
Default Rich or lean? I'm really confused O.o
Hello
I recently got a new engine its an Omega X2 .21 by team Picco.
I almost finished breaking it in using the traxxas method and i'm on the last one. When I W.O.T it bogs and sputters (kinda like what you see on movies when the car runs out of gas or the engine explodes) and then dies.
From my experience I know this is signs of it being lean...but i've turned the needles to the left which is rich? and it still bogs and sputters. Anyone know what the problem is?
Thanks.
Old 07-01-2009, 07:36 AM
larryf333
larryf333's Avatar
Default RE: Rich or lean? I'm really confused O.o
Yes, counter-clockwise is richer. You're LSN is probably set too rich. After you start it, bump the throttle quickly a couple times, then try to move. This should clear out the carb enough for you to get it moving, then you can tune much easier.
Old 07-01-2009, 07:41 PM
golfingguy27
it is most likely the low speed needle. Get the engine running then let it sit at idle.. if it eventually slows down and/or dies completely it is most likely too rich, which is what I am guessing is the case. It's loading up with fuel.
Old 07-02-2009, 08:06 AM
Xtfreak
Xtfreak's Avatar
It idles fine, really high then slows down and idles till the gas has run out.
