Boat turns right constantly
Old 07-10-2009, 09:01 AM
mikewait
Default Boat turns right constantly
Hi my team pro turns right when i try to go straight (when i don't touch the steering)
I think it might be the water pick up causing drag because it's on that side.
My rudders are set straight... so it must be the water pick up that slightly sticks out.
I have this kind of pick up [link=http://9x4br.64n2f.servertrust.com/ProductDetails.asp?ProductCode=WP3035]http://9x4br.64n2f.servertrust.com/ProductDetails.asp?ProductCode=WP3035[/link]
What can i do to fix it???
Old 07-10-2009, 10:43 AM
pompebled
Default RE: Boat turns right constantly
Hi Mike,
Not knowing what type of boat the Team Pro is, I think I can safely assume that what you're experiencing is the propwalk effect.
Every single prop driven boat is affected by it.
A few countermeasures are:
- having the leading edge of the rudder at the same distance from the transom as the prop (with a surface piercing drive).
- mounting the entire drivetrain off center (to the right, viewed from the rear)
- shifting the motormount off center, to the right
Having the waterpickup on the right surely doesn't help, can you shift it to the other side?
Do you have some pics of your set-up, or a link to the boat?
Regards, Jan.
Old 07-10-2009, 10:53 AM
martno1fan
martno1fan's Avatar
Sharpen the prop and if your drive is in the centre then shim the strut or stinger with spacers so your prop is angled left slightly this will make her run straight just use washers it only needs to be one on each bolt on the right as your looking at it just slip them under the strut that should do it.best thing to do really is remove the strut and move it 1/4" to the right but thats more work.No need to mount the motor to the right thats why we use flexable drives .
Mart
Old 07-10-2009, 11:44 AM
mikewait
Ok, i took a few pictures of my boat in my garage, here they are i hope... first time posting pictures hope it works lol
What do you guys think i should do to get it to go straight? What would be the easiest??
ID:	1233354   Click image for larger version
ID:	1233355   Click image for larger version
ID:	1233356   Click image for larger version
ID:	1233357   Click image for larger version
ID:	1233358   Click image for larger version
Old 07-10-2009, 11:58 AM
martno1fan
martno1fan's Avatar
First try a better prop looks dull,is it aluminium or just not sharpened and balanced?.Id buy a better sharp ballanced prop then try it,might run ok.if not shim the strut.
Mart
Old 07-10-2009, 12:13 PM
pompebled
Hi Mike,
Like Mart said, see to the prop, a dull one generates much more propwalk than a shiny sharpened one with thinned blades.
If that doesn't help enough, trim the strut, as suggested.
Let us know how thins develop.
Regards, Jan.
Old 07-10-2009, 12:48 PM
martno1fan
martno1fan's Avatar
Also you can balance and sharpen them yourself theres plenty of info on that in the main boat forum.My advice though would be buy a really nice ballanced prop froma reputable source such as Chris Hoffman aka dasboata,hes great for advice and his props are the dogs wotsits .While your enjoying running that one you can try and work on the dull one and use the new one as a benchmark so you have an idea of just how thin sharp and balanced they really are.
Mart
Old 07-10-2009, 01:25 PM
mikewait
Alright i actually noticed it was really dull a few days ago... i have spare so i will see if it's any better...
If not i will research for a new one
Old 07-10-2009, 01:36 PM
Dreamin Hemi
Dreamin Hemi's Avatar
Isharpen mine enough to cut paper. That prop you have looks like the standard 275 that WHH sells with every package and definately untouched....I have several of them.
Old 07-10-2009, 02:17 PM
mikewait
I sharpen mine enough to cut paper. That prop you have looks like the standard 275 that WHH sells with every package and definately untouched....I have several of them.
So what's another prop thats better quality than the 275? But is similar or better in performance...
And did it get rid of some of the prop wake sharpening it???
Old 07-10-2009, 03:49 PM
martno1fan
martno1fan's Avatar
Theres nothing wrong with that prop it just needs balancing and sharpening ,have a read up on how its done theres a sticky on the main boat forum.The 275 is one of the best all round props there is,just sharpen and balance it no need for it to cut paper thats not needed.Last thing you want is to cut yourself every time you go near it [:@].
Mart
Old 07-10-2009, 06:22 PM
danielplace
Make sure you don't have more right tab in it than the left also. Only a 1/16" can make it pull. Get the prop good and sharp and everythingf will work better. Is the boat running dry enough and not plowing cause that can make a boat want to bow steer and it usually favors the right side.
Daniel
Old 07-10-2009, 07:31 PM
MrMikeG
Looks like your drive is mounted too low too
Old 07-10-2009, 09:15 PM
t00fatt
t00fatt's Avatar
My magnum with the same prop, prop walked pretty bad until I sharpened the prop. The leading edge of my prop came completely flat, not even an edge to it.
Old 07-10-2009, 10:51 PM
Ron Olson
Ron Olson's Avatar
OK. I'll throw in my 2 cents. It sure looks to me like the rudders aren't parallel to each other, basically toed in.
That prop is really dull also, it really shows up in shot four. That will give you a paddlewheeling effect (propwalk).
Old 07-11-2009, 08:27 PM
mikewait
Alright thank you soo much guys for the awesome comments!!!
Im going to mess around with my spare prop and hopefully make it sharp.
I think ill recheck the rudders and trim tabs to make sure they are adjusted right.
but once again thanks for the help i would have never known that a unsharpened prop can create so much prop walk!
