HPI Rush
IN,
HPI Rush
Move the battery pack to the front of the truck (over the receiver), toss the stock "X" pattern tires, use HPI blue springs in the rear with a 40wt shock oil and get a stronger steering servo.
Having the battery pack hanging off the rear end like it does makes the Rush extremely light up front. If you move the pack forward and stiffen up the rear a little, the front end will stay planted better.
Also the stock steering servo is plain old crap! The front wheels deflect all over the place when you run offroad. Something with higher torque (Hitec 645MG) will help keep the nose pointed where you want it to go.
Good luck!
Good luck!
