Respirator
Old 07-28-2009, 02:49 PM
Showtime100
Showtime100's Avatar
Default Respirator
Will I need a respirator for Nitrate Dope in a shed with a large opening? I haven't popped the lid yet and wondering how toxic this stuff is?
Old 07-28-2009, 03:53 PM
Les Nessman
Les Nessman's Avatar
Default RE: Respirator
Hi Showtime, this is a bit of a loaded question, I don't want to here you were found laying on the floor doing the funky chicken. If painting with other oil base paints does not bother you too much, you will be fine with a large opening for ventilation. If you start to feel light headed better take a break.
Old 07-28-2009, 03:56 PM
Showtime100
Ok, sounds like common sense is needed. I just didn't know how toxic it was and work for an hour with it and find out my lungs are falling apart because I didn't wear a respirator.
Old 07-29-2009, 08:19 AM
Chip_Mull
Chip_Mull's Avatar
Showtime: The Dope only requires a carbon filter mask or an organic mask to paint. Check the mask by putting it on and holding a rag with reducer or lacquer thinner or paint on it next to the mask. If you can smell anything the filters are bad or the mask is loose.
Dope will kill a few brain cells but is not carcinogenic (won't cause cancer). This usually starts an extremely long thread but if you go to the EPA web site it has a lot of things like "May" and "Could" but no definitive results. Dope's main ingredient is MEK and toluene and that's what you need the mask for.
Dope does not require a fresh air breather.
Please do not jump on this and start one of those diatribes about MEK and its inherit dangers. The man only asked if he needed to wear a mask. Yes, a simple one.
Old 07-30-2009, 06:44 AM
Rudolph Hart
Rudolph Hart's Avatar
Chip gives good advice showtime.Remember to store your mask and filters away from the workplace and wrapped or boxed in something.They absorb the enviroment they are in without the need for you to suck any air thru the filter yourself.
Old 07-30-2009, 08:15 AM
Showtime100
They have these at the local hardware store. I'll be sure to pick one up.
