Evader SP
Im pretty new to r/c cars ive been working on fixing up an Evader i found at a garage sale that was pretty beat up. recently it began having problems with from what i can guess the motor, transmission or differential. itll be running and just randomly stop, if i push down on the cover, or the motor itself it generally starts back up after a few tries. Tonight when i was out running it, it would stop, and then id have to push it alittle bit and itd start up, like a rolling start. I tried tightening down the gears a bit, but they looked like they were meshed just fine and werent worn down. Is it possible that the motor is just gone?or is it something much simpler. It ran just fine about a month ago the only thing ive really done is added new front shocks. Any help would be great, id rather not bring it in for repairs.</p>
The brushes are worn out, if it still has the old Photon Speed motor then you should get a different one anyway. The Team Orion Method R motors are great for the price, look for the ones with adjustable timing and ball bearings. Also, is it still running the Sprint ESC? That ESC is rated for 20 turns minimum, but it'll handle a 19 turn just fine, so a Team Orion 19 turn or Trinity Speedgems should hit the spot nicely.
My Feedback: (325)
The 7 cell pack will make it wear out faster since it is making more power now. You may have very good results from just cleaning it out with motor spray real good. A drop of oil on each bushing after the cleaning will be good. It probably does need new brushes and comm cut if it's the evst. If it's the ext then the motor is a throw away.
its an Evader SP, its older im guessing. How do i go about cleaning the motor or do i just spray it? And will my local R/C store carry the brushes and comm cut? Any other reccomendations besides the Orion, ive seen that name throw around so ill look into those next time im at the store. It has the intellispeed ESC in it currently i do have the original as well. Heres a link with the specs, http://www.duratrax.com/caraccys/dtxm1055.html .
I talked with someone local, he said it might be the reciever but it still turns so i dunno if thats a possibility or not. i swapped out ESC for the original and it did the same thing. When i apply throttle to go forward i get a red light, when i reverse i get both green and red, when doing nothing it blinks green. Sorry im on a college budget so i dont wanna buy the wrong part, payments due soon.
man you picked the wrong hobby to be in if your on a limited budget lol its the motor the one in my rusty just started doing that and i swaped it now its fine
Lol yeah I realized that when I went to the store. Oh well I picked up a second job so I should be good to feed my new addiction. Thanks guys ill go grab a new motor.
