Aeroworks Edge 540T
Aeroworks Edge 540T
I finally got my Aeroworks Edge 540T from Lester's Hobbies in Nakusp, B.C. Its non- flashy box was within another shipping box and it arrived in my hands in really good shape. The covering is better than what I would have been able to achieve. Upon close inspection of all the laser-cut joints and seams, there is a very clean liberal application of CA or epoxy. The fiberglass nose and wheel pants are super clean, paint wise and trimming. The hardware is of top quality and I am sooo looking forward to the build and its completion. But first, I thought I'd ask for any recommendations before I begin the assembly. I plan on powering it with my Saito .91. It's going to be 2.4ghz on a 2700 6V rx pack. I've got 4 DS821 70 oz digital servos from the DX7 flight pack, 4 hs645mg's, 2 hs475hbs. Not sure whats the best to use where.
My Feedback: (13)
NJ
RE: Aeroworks Edge 540T
Use the minimum recommended on all surfaces...but def give the best youve got on the rudder. Should fly really well with the satio 91. Ive got a saito 100 in mine and its tons of power. So you should be fine.
This little plane is a beast and alot of fun to fly. You'll see!
Go here for alot of great info:
http://www.rcuniverse.com/forum/m_3517297/tm.htm
That was a lot of reading! Thanks for the link.
I got it done in, ready to start the motor and taxi trial. Two days from box to sittin' pretty. The only real tough thing to do was install the tank with a Sullivan fuel valve. The design has changed to include a larger tank. Mine came with a 450cc tank. The plane is different than the instructions in that regard. For the fuel tank cut out in the fuse, I had to notch the corner to allow clearance of the throttle linkage. Other than that, it went fairly smooth besides the fact I was chasing my 3 1/2 year old around! LOL. We can't wait to put some fuel in and fire this puppy up!
After a bit of fartin' around trying to balance and gettin' the flyin' gremlins outta the motor (first run since Mid-Star crash), I had my maiden flight! WOW!! I had only a short flight of about 6-7 minutes, but WOW! I ran with a 14x8 on %15 and cannot believe the response! Had experienced that wing drop upon landing but I had enough speed to correct and land OK, not the best one I've had, but definitively not the worst! This is the kinda fun I've been after! Soon, after a few more flights, I'll go a little extreme with it. Anyone into sport planes, get one! Price point cannot be beat!
My Feedback: (13)
NJ
I sorta had the same initial reaction as you did. Once I got the CG set right.... it totally changed. The plane would just float on idle and would just do anything you want it to. Inverted was almost hands off. I love this plane!
ORIGINAL: RevyMaxx
That was a good maiden! Be sure to get yerself a good 14-6 wood prop so u can put yer lock nut back on. You don't want it to back fire and spin the prop off in the air [X(]
I was going to suggest a xoar but I see they don't make a 14". They start at 15" But,!!! You could run a 15-6 with 25%
My Feedback: (13)
NJ
Actually Xoar does make 14" go here.....http://www.abellrc.com/abellrchome.html
My Feedback: (13)
NJ
Very Sweet! You'll love this plane once you get everything dialed in.
If you start to break alot of wood props...Just use an APC for the time being even though Xoars are said to be better for faster spool up. However the APC works well, should be better than the MAS - alot less flexing. I tried a Xoar prop and broke it without even taking off. I was pissed. So threw the APC back on.
Interesting, my landing gear is red, your's is white. Im jealous!!!
Also looks like you have an amazing field to fly at. Jealous again...Enjoy!
ORIGINAL: anuthabubba
What is the total weight without fuel? I'm considering getting one but won't if it is too heavy.
Terry in LP
Terry in LP
ORIGINAL: f5air
good setup...dont forget to check the thread on the 3d flying...we are always posting new things there...lol.
ORIGINAL: ro347
[&o] $40, oops... The xoar are very brittle at the tips but the difference in power between my zinger pro 22-8 and my xoar 22-8 (good unbroken one) is outstanding. Honestly makes the difference between a pull out and flopping over in its back!! not kidding. Plus the zinger was giving me 6900 rpm and the the xoar gave me 6600 but had WAY more pull.
We are spoiled with such a nice field. Here is a better pic of our field. I took this in July of this year. The water is up but for the most part stays out 300-400 feet.
SC
nice to hear good things bout the aeroworks 540. got one on the way. i been away from hobby bout 4 yrs. i been flyin fun star 40 size last few weeks. cant wait to get 540. i was hoping it would be a good performer !!
