buggy stop running
DC
buggy stop running
my electric buggy stop running. giving it a push, it 'd run a few feet then it choked. and it usually dead after a swift stop.
is the esc damaged? i m using a tamiya stock motor. what should i do to pinpoint the part?
Banned
RE: buggy stop running
Things to check: check the motor. It may be time for a new one. Check the wire leades fron the esc to motor. They can come loose or get coroded. check your ESc to see if it has a thermal overload protection If it does try a new motor. If it has a fuse replace it and try a new motor. IF not then a new ESC.
DC
thanks
ORIGINAL: rendezvous944
How long does it run before it quits ? This doesn't sound like an ESC problem. It sounds more like a motor in need of new brushes but the Tamiya motors aren't re-buildable so it might be time for a new one.
DC
i got the truck a few months ago.
it stops in a few seconds after a push.
ORIGINAL: john01374
DC
7.2V 5000mah
discharge & quick charge cycle trice
ORIGINAL: Druss
Also make sure the battery is fully charged. What battery and what voltage does it read?
