Dartman's ZipKits I box.
Old 10-04-2009, 09:33 PM
Dartman1074
Default Dartman's ZipKits I box.
Well my I box is getting closer to being done. Only a few more things left to do. Need to go pick up a new remote and get the linkage's all hooked up. I started it today for the first time. Sounded good.. Here are a few pics. Also need to paint the cover. Should have it all done by this weekend..
ID:	1288406   Click image for larger version
ID:	1288407   Click image for larger version
ID:	1288408   Click image for larger version
ID:	1288409   Click image for larger version
ID:	1288410   Click image for larger version
ID:	1288411   Click image for larger version
ID:	1288412   Click image for larger version
ID:	1288414   Click image for larger version
ID:	1288415   Click image for larger version
ID:	1288416   Click image for larger version
Old 10-04-2009, 10:47 PM
mymammushouse
Default RE: Dartman's ZipKits I box.
thats an awesome paint job
Old 10-05-2009, 03:27 AM
nooh
nooh's Avatar
ORIGINAL: mymammushouse
Where's my Sunnies. Great Job Dart..
Old 10-05-2009, 06:21 AM
martno1fan
martno1fan's Avatar
Very nice mate what paint did you use it looks great well done.
Mart
Old 10-05-2009, 11:17 AM
Hesco Racing
Holy [:@] now that's a paint job. I'd be to scared to run the boat with other hooligans.
Cobus
Old 10-05-2009, 06:34 PM
Dartman1074
Thanks guys. The paint is base coat clear coat. The outside of the pinstripe changes to a few more colors. Couldnt get it to show up on the camera. The paint has this diamond dust and gold flakes in it.
Old 10-05-2009, 06:48 PM
Dartman1074
Here are a couple of pictures from the earlier stages of the build. Right after being painted and a few days later. Kinda shows more of the colors changing. Thank You every one again. This was my first build and was very fun. Will prolly be building another boat sometime.
Tim
ID:	1289030   Click image for larger version
ID:	1289031   Click image for larger version
ID:	1289032   Click image for larger version
Old 10-05-2009, 07:13 PM
stackeddeck
Looks like you did a much better job on your first build then I am on mine lol... that boat looks A-mazing!
Old 10-05-2009, 08:40 PM
gtopillado
gtopillado's Avatar
Spared "no expense" to that build, looks awesome!
Old 10-06-2009, 06:26 PM
sheograth
Moderator
sheograth's Avatar
Great looking boat, as others have said the finish is awesome.
Old 10-10-2009, 03:05 PM
ByronRC
ByronRC's Avatar
Dartman, where do you run? I just moved to Clearwater and would love to see that boat.
Old 10-10-2009, 11:03 PM
Dartman1074
I am not real sure yet..lol I need to figure out a good spot to go. I will let you know if i figure out a place.
Old 10-17-2009, 05:45 PM
Dartman1074
Well She finally got wet today. Didnt start off very well. Had some prob's with it not wanting to turn. Thank god there was a hobby shop 2 seconds away. Got that fixed.. Next I need to get the trim tabs set right. She is very unstable.. Flipped it once and landed right side up and kept going. The last flip wasnt so lucky. Other than a few things that need attention. She ran very well. Got every thing all dry and going to try again tomorrow.
ID:	1296957   Click image for larger version
ID:	1296958   Click image for larger version
Old 10-17-2009, 06:18 PM
nooh
nooh's Avatar
Congrats on the Maiden m8, Now the real fun starts in tweaking her to run her as fast as she can.. Well done..
Old 10-17-2009, 06:26 PM
Dartman1074
Thank You! It was very rewarding to finally get her in the water. I am still new to this. "Have nitro trucks" So I have some learning to do on the adjustments to get her running right. As I said before she was very loose. Seemed the nose was out of the water to much. Tonight I adjusted the trim tabs . So tomorrow Ill see how that does.
Old 10-17-2009, 06:44 PM
foodstick
foodstick's Avatar
good for you man ! I know i was smiling the first day out with mine ! I have the same boat and really like it...
Old 10-17-2009, 11:04 PM
Dartman1074
I am ready to get this thing back in the water again.. I am wondering if I should mess with the trim tabs or lower the skag or even angle the skeg a little. I am not sure what to do. Any help on setting her up to handle a little better would be great. The front of the boat seemed to ride a little to high. Sorry for all the ?'s I am pretty new at this.
Old 10-18-2009, 01:58 AM
sheograth
Moderator
sheograth's Avatar
Congrats on getting it running. I still can't get over how gorgeous that paint job is...
Old 10-18-2009, 02:39 AM
painman
Make sure the strut has no positive angle, this would raise the bow and make the boat loose. you might even try a litle negitive on the strut and use a straight edge on the bottom of the boat to set the trim tabs. I would sart out with them straight with the straight edge then if the boat is still to loose then add more trim tab(adjust down) this agin should help to settle the bow of the boat. If all this fails you might have the CG to far back and need to move some weight forward toward the bow.
I would try all the above first before you start moving anything around, the boat has an awsome finish, very pretty paint work.
Good Luck;
Randy[sm=shades_smile.gif]
Old 10-18-2009, 09:17 AM
Dartman1074
Thank You very much. I will try that. as for the motor im not sure I can move it much more. Its pretty close to the front now. hopefully everything else will work. Thank You again and for the complements on the paint work too.
Tim
Old 10-18-2009, 06:08 PM
Dartman1074
Today was much better. I have it handling alot better. It was alot of fun running today. I cant wait till next weekend to get back to the water.
Also here is a short video
[link=http://www.youtube.com/watch?v=6ANMtFQilqs]CrackerBox[/link]
ID:	1297700   Click image for larger version
ID:	1297701   Click image for larger version
ID:	1297702   Click image for larger version
ID:	1297703   Click image for larger version
Old 10-18-2009, 07:57 PM
painman
Glad to hear that you have had a good time with the boat, and are having a Blast. If there is any way I can help I would be glad to.
Later; Randy
Old 10-18-2009, 08:02 PM
Dartman1074
Thank You again for your help. I did have a blast today.
Old 10-25-2009, 06:39 PM
Dartman1074
Well today was a pretty good day. The cracker ran pretty good I think for being pretty much stock. Stock G260, Tuned pipe set at 14 inches.. Octura X670 Prop.. Went and picked up a GPS today and got a reading of 40.1 the first run. And the last run came up with 43.4.. Not to bad I think.. The pic was taken with my phone so its not that good. Forgot the camera today... Now I need to figure out what prop to try next.. Any sugestions?
ID:	1301809   Click image for larger version
Old 10-25-2009, 10:33 PM
ByronRC
ByronRC's Avatar
Dartman, it looks like I missed out[:@] Don't count me out running with you though, I had to work this Sunday. Slide me a PM the next time.
PS Your boat looks great.
