Heli Connection Fails Mid Flight
PA
Hey guys!
I am occasionally having a problem with my Novus FP (Walkera 4#3B).
The transmitter (TX424) will bind just fine to the receiver/esc on the heli (RX2400) when I power everything up to start flying, however on certain occasions when I give the heli enough throttle to get off the ground, the heli and remote will stop communicating in the air and it will fall to the ground, and I'll have to turn both the transmitter and heli off and restart the flying process. It seems as though in these instances, giving the heli around 40% throttle will cause the sold red LED on the receiver of the heli (solid red meaning it's bound), to just randomly change to slow flashing, and I no longer have any control.
I already emailed the tech support for Heli-Max, but I was wondering if this was a common problem, hoping for a quick fix. Any suggestions?
Thanks in advance!
MR.FEESH
Thanks in advance!
MR.FEESH
PA
Well... lack of responses to this thread and annoyance that I couldn't fly combined, and I ordered the brushless upgrade which comes with all new electronics. I installed the brushless esc, receiver, and motor... tested the bird today, and all systems are A-Ok.
VA
I,m willing to bet the plugs are causing it to read a low lipo cut built in I cut off the stock plug and went bl as well and added a slight bend to the esc powerplug (upward) to make a better connection when the battery/esc are plugged into each other one day they will all be micro deans but I have a whole lot of batterys and those little things are pricey if you need a bunch
![EEK!](images/smilies/eek.gif)
