Strut any good??
Strut any good??
Old 11-10-2009, 09:19 PM
Wiseco80
Default Strut any good??
would this strut work good on a AEROMARINE Sprint Cat???
ID:	1311956   Click image for larger version
Old 11-10-2009, 11:14 PM
nooh
nooh's Avatar
Default RE: Strut any good??
Take a look at this thread m8.. http://www.rcuniverse.com/forum/m_9233453/tm.htm Looking at your strut and looking at the Pics of a Sprint Cat I doubt that it would work. Even if you did manage to fit it to the boat there would be no length left in the strut for adjustments ...
Old 11-10-2009, 11:36 PM
Dan S
Dan S's Avatar
ORIGINAL: Wiseco80
Too Short.
Dan
Old 11-11-2009, 12:45 AM
Wiseco80
ORIGINAL: nooh
The guy i got the cat from did had that strut on there.. the tube slides right in the strut.. will take a pic of it on there in the morning...... am just getting into boats My first Built :-)
Old 11-11-2009, 01:19 AM
Wiseco80
here i took some pic of it on the cat... i wanna just know would it be a nice setup. am waitin on the speedmaster rudder!!
ID:	1312146   Click image for larger version
ID:	1312147   Click image for larger version
Old 11-11-2009, 03:34 AM
nooh
nooh's Avatar
Good luck on your first build Wiseco80, Just think you will have big problems with this strut, Like I said it might fit but there no room for any adjustments, I agree with Dan that it is way to short.
Henry..
Old 11-11-2009, 09:59 AM
Wiseco80
ORIGINAL: nooh
Henry..
what kinda of problems i will be having???
Old 11-11-2009, 11:13 AM
blizard05
blizard05's Avatar
That strut is from S.M.E, It should work,however most run a skeged strut on there cats
Old 11-11-2009, 01:30 PM
Wiseco80
ORIGINAL: blizard05
What company is that S.m.e ??
Old 11-11-2009, 02:31 PM
Ron Olson
Ron Olson's Avatar
Looks OK to me but it just needs to go lower. Maybe I'm missing something that the others are seeing.
Old 11-11-2009, 02:57 PM
Doubledog
My Feedback: (48)
Doubledog's Avatar
Yep, +1 for going lower.
Old 11-11-2009, 03:25 PM
Dan S
Dan S's Avatar
[/quote]
[/quote]
reason I say too short is by looking at the picture it does not seem that you will be able to bring the strut all the way down to the sponson.
what I am trying to explain is,
put your cat on the table, now try to get the bottom of the strut to be flat on the table.
you want to be able to go that low because depending of prop, water conditions and other factors you final strut adjustment will be somewhere from level on the table to 1/2" above.
Dan.
Old 11-11-2009, 03:56 PM
blizard05
blizard05's Avatar
ORIGINAL: Wiseco80
ORIGINAL: blizard05
S.M.E scale model engineering, making hardware for over 20 yrs
Old 11-11-2009, 04:18 PM
Wiseco80
ORIGINAL: Dan S
you want to be able to go that low because depending of prop, water conditions and other factors you final strut adjustment will be somewhere from level on the table to 1/2'' above.
Dan.
dose that tube that come out the hull have to be eazy to bent up and down???
Old 11-11-2009, 07:27 PM
blizard05
blizard05's Avatar
ORIGINAL: Wiseco80
ORIGINAL: Dan S
Dan.
NO, should not be easy
Old 11-11-2009, 07:44 PM
Wiseco80
Ok cool sorry for all the noobie ???? like i said new to the boat thing more into cars :-) ...... so how would you adjust the strut down with it brakein the tube off the hull can its real hard to Move
Old 11-11-2009, 08:25 PM
Ron Olson
Ron Olson's Avatar
On my Cat hulls I've found it easier to epoxy the next size larger tube in the bottom of the hull then insert the stuffing tube into that. This way if Im cut it too short, kink it or whatever other problem I can easily take it out and replace it. Some add a touch of solder to keep them in place using this method.
If you want to try what I described above then you can cut off and then drill out the old tube with minimal damage if any.
Old 11-11-2009, 11:58 PM
danielplace
Other than not having a skeg on iy that most cats need to turn well without sliding it looks like it will be just fine to me. The way it is mounted now I can see almost another inch of slot left although the stuffing tube looks to be bent more for where it is now. Many cats run with the strut or propshaft centerline almost 5/8" above running surface depending on prop. It should work ok if on a budget for now.
Otherwise I would get a Speedmaster skegged strut for it.
