Covering for plans
I have viewed and studied the monokote piece done by lomcevek1.
My question, if the GLAD press and seal film is referred to saran wrap with an adhesive can it be used for plan protection on a building board.
Waxed paper recommended, saran wrap acceptible but on the press and seal will it lift part of the plan when removed.
I am not confident myself to try it, but if anyone has had success and would it be cost affective?
My Feedback: (9)
The best stuff I've found for protecting plans is the film that movers use to protect stuff. The last time I moved I grabbed several left over rolls. It sticks to itself which can be a pain, but it does a great job of protecting plans and CA does not adhere to it. I think you can buy it at U-Haul type stores.
Walt
Walt
I've never used anything other than Waxed Paper to cover plans, and can't see a reason to use anything else. Its dirt cheap, its readily available at any grocery store, the box is easy to store, and nothing sticks to it. A small piece of masking tape at the corners to hold it in place. There's no reason I can see to want anything to adhere to the plans.
Or are you asking about other materials to use for the monokote decal technique using the Press and Seal?
Brad
Brad
ORIGINAL: bkdavy
Brad
Brad
Wax paper is a good first choice, however with the conveince of copy machines these days my first choice is clear packing tape over a copy. That way you don't mess up your origional plan. By the way, years ago I had several disappointments with cheap wax paper, so I only recommend Cut Wright wax paper. The glue
somehow seeped through the cheap wax paper. Greg
MI
The press and seal will work on your plans. It is a little tricky to get it on your plans because of the adhesive backing. It helps to have another person when working with large strips in order to get it to lay flat. But it wont harm your plans. It has stickyness but not that much. I have used it and after a project it will pull off fairly easy. I don't know if it would be a problem if you stored your plans that way for long periods. CA does not penetrate it. By the way I have tried the "monokote 301" method and it works great. The hardest part is keeping a sharp blade and getting sharp cut lines. Here is some photos of my first try.
ORIGINAL: tacx
The press and seal will work on your plans. It is a little tricky to get it on your plans because of the adhesive backing. It helps to have another person when working with large strips in order to get it to lay flat. But it wont harm your plans. It has stickyness but not that much. I have used it and after a project it will pull off fairly easy. I don't know if it would be a problem if you stored your plans that way for long periods. CA does not penetrate it. By the way I have tried the ''monokote 301'' method and it works great. The hardest part is keeping a sharp blade and getting sharp cut lines. Here is some photos of my first try.
What are some of the best ways to fill weave in .56 weight per yard fiber glass mat? It is on a 1/5th scale P 51 mustang and I'm concerned about the brittleness of nitrate dope for filler. Does caster oil really solve this problem? Products I've had mentioned are DAP lightweight, Hobbico balsa filler and talk added to dope, can't even find any pure talcum powder. Need help.
tacx, did you have any residue left from the press and seal? My efforts left a hazy coat on everything that I had the press and seal stuck on. The residue did not wipe off with alcohol. I was afraid to use it as a plan protector for this reason. thanks
Although not perfect, I've had good luck with wax parchment paper from the baking department at Wal-Mart. I formerly used regular wax paper but now it seems the companies are getting stingey with the wax coating.
MI
Star7,
I have not had a problem with any residue. Like i said I have used it on plans but not for prolonged storage. I have used it on my monokote and it left no residue.
CO
Igot a big roll of hardward store plastic film found in the paint isle. Ijust cut what Ineed, and nothing sticks to it.
I also build a magnet building board, which has done wonders for preserving my plans during a build - vitually untouched after a build.
MI
I am currently using the clear backing from a roll of MonoKote. I was very careful to save a much as could from my last two covering projects. I hope it lasts since I will probably be using more UltraCote in the future and it doesn't have clear backing. I have used the plastic film for shipping pallets, but once I put a pin through it, the hole seemed to open up and allow glue onto the plan.
ORIGINAL: FIGHTERACEX
Parchment paper, used wax paper for years once you change to PP you will never look at wax paper again.
![Frown](images/smilies/frown.gif)
Mike
ORIGINAL: KitBuilder
Where do you get the parchment paper at ? I'm using wax paper and have for years but I remember as a kid it being more waxy. Today it seems CA will stick to it more easily. I guess they cheapening the product like most other things
. Does parchment have some sort of coating on it?
Mike
Mike
I wonder what it would cost to have your plans laminated..
That might be another good option.. put a sheet of laminating film over the plans.. (I have never tried this. Just a thought)
Parchment is silicone impregnated.. good stuff. Great for baking too
A wide roll of parchment is my choice. Hard to find the thinnest though. Don't go for anything marked heavy duty thats for sure. I think I might try a donut store. ![Smile](images/smilies/smile.gif)
Plastic is good too but it relaxes sometimes and you have to keep re-tacking it and it can also have nasty buckles in it from being folded if its that type.
Just to waste some time and take some pics ...
pic 1 - parts = LT-40 plans, wax paper, press-n-seal & lite plastic sheet from Home Depot
pic 2 - My LT-40 plans with no covering
pic 3 - plan + press-n-seal
pic 4 - plan + press-n-seal partially removed (no damage to plans)
pic 5 - plan +wax paper
pic 6 - plan +plastic sheet
The best plan visibility seems to be with the plastic sheet, next press-n-seal and then wax paper. The tape that holds the wax paper and plastic sheeting is most destructive thing about coverings. Press'n Seal doesn't need tape.
ORIGINAL: SeamusG
What started as a curiosity factor turned into quite an informative thread.
Thanks to all.
