Nitro Fuel?
My Feedback: (10)
RE: Nitro Fuel?
What makes it so bad? The guy at our LHS uses it and he's sponsored by CENRacing. He ONLY uses that fuel. What is wrong with it?
ORIGINAL: fourwheels0
blue thunder 20% or o'donnels 20%. traxxas fuel is got to be the worst fuel out there imo.
RE: Nitro Fuel?
ORIGINAL: SyCo_VeNoM
Aint 16% for boats or airplanes?
The only thing that may be needed when changing nitro percentages away from factory reccomended is adding/removing shims and retuning to the new fuel.
RE: Nitro Fuel?
Lots of people have a dislike for Traxxas Top Fuel because it has a lot of oil and OWBs seem to slip a lot when using it. They, Traxxas, has since come out with a different blend. I don't have any experience with that fuel and so don't know if it is good or bad. I know I won't use Traxxas original formula. Nor will I use Blue Thunder as I have had a terrable experience with that fuel.
I do really like the O'Donnell's fuels.
My Feedback: (10)
RE: Nitro Fuel?
Thanks for the feedback. I will certainly look into that because I don't want to do any damage long-term using junk fuel. I think my LHS ONLY carries that brand though @ $30/gallon.
RE: Nitro Fuel?
yeah I ran traxxas top fuel once...never again...my engine didnt like burning it and my one way bearing didnt like it either...
if your just bashing around I'd run 20%...25% and 30% is more for racing (I'm racing with 20% but when I get a new race mill I'll move to 25%)...I run byrons but odonnel makes good fuel also...byrons, odonnell, trinity and traxxas is the only fuels I am familiar with.....
rast was correct...it will run on 20% an thats what I would use....also I have pretty much the same buggy...your gonna like it...they are very well built and they will take a beating...I've beat the tar outta mine and it just asks for more
Banned
RE: Nitro Fuel?
ORIGINAL: Kandy_Man
I am running a HBX VRX-2 buggy. and on the website they only sell 16% nitro fuel. is this to little percentage?
thanks
thanks
I fly planes too and sometimes run my plane fuel in my cars, no problems.
My Feedback: (7)
RE: Nitro Fuel?
the problem with traxxas fuel is you have to run the engine to lean and hot to get power out of it because of the oil in it. plus you had to mess with the needles all the time.
even the new 33% traxxas fuel is not that good. still too much oil. i beleive they do that because it's marketed for people just starting out in rc.
the blue thunder was alot better and the o'donnels was even better. all i run now is o'donnels 30% and have no tuning issues and great power.
i've run o'donnels in everything from os18tz's,hpi,fantom,lrp,ninja and a few other engines and never had a tuning issue,heat issue or longevity issue.
RE: Nitro Fuel?
ORIGINAL: rast4man
What would be the proper way to go from say 20% Traxxas to 30% O'Donnels? Would it affect the motor switching fuel or just have to re-tune to the new fuel and climate?
Any time you change fuels you will need to retune. Heck, you should retune when you switch to a fresh gallon of fuel even if it is the exact same brand/percentage, etc.
My Feedback: (10)
RE: Nitro Fuel?
Thanks. I'm looking into theor fuel but my LHS doesn't stock it and I don't know if he'd order it just for me. Any leads on a decent place that ships? amainhobbies only has a quart of 30% it looks like and Tower has this http://www3.towerhobbies.com/cgi-bin...LA6227&P=1 for like $120.
ORIGINAL: DaveG55
O'Donnell's makes 20% fuel as well. Unless you are a hard core racer there's not a lot of benifit to going to a higher percentage fuel.
ORIGINAL: rast4man
RE: Nitro Fuel?
ORIGINAL: rast4man
Thanks. I'm looking into theor fuel but my LHS doesn't stock it and I don't know if he'd order it just for me. Any leads on a decent place that ships? amainhobbies only has a quart of 30% it looks like and Tower has this http://www3.towerhobbies.com/cgi-bin...?&I=LA6227&P=1 for like $120.
ORIGINAL: DaveG55
ORIGINAL: rast4man
[link]http://www.amainhobbies.com/product_info.php/products_id/145543/n/Maxys-25-Pro-Racing-Fuel-Four-Gallons[/link]
I have not personally tried it but it gets nothing but great reviews. And for $15.75 a gallon it is a no-brainer. I never really liked O'Donell much anyway, the performance is good but it is very toxic so make sure you can hold your breath for a while when tuning the idle and low speed neeedle. Your eye's also tear (spelling? a drip of water coming down from your eye) quickly.
VA
RE: Nitro Fuel?
guys at the track go to told me in Europe 16% and 25% nitro are the norm.
you should have no problem running it on 16% i used to run some my engines on 10% when i started running nitro.
MN
RE: Nitro Fuel?
ORIGINAL: rast4man
It has a Go motor so I would think it should run on 20%. I could be wrong on this particular motor so hopefully someone can confirm.
If you admit there is possibly some false info in you post then why are you postiung in the first place????????? get you facts straight then try to help people.
