Market place mouse info
My Feedback: (251)
HI all, has anyone else lost the the convenience, of using the mouse to get info from the description in Market Place adds for Jets and others
It was very handy to check the number of offers, without going into the post. I had it 2 weeks ago and now it does not work. Some others I have spoken to, do not have it now.
Are their others that it does not work now.
Rcpete
Rcpete
My Feedback: (15)
MN
RE: Market place mouse info
Seems to be an issue with Internet Explorer version 8. If you try to mouse over when using IE 8 and you should get an error/warning on the bottom status bar as in the image. This does not happen with older versions of IE and Firefox.
My Feedback: (15)
MN
You may not have the status bar turned on. go to View -> toolbars-> check status bar. you wont get a pop up error as by default IE 8 has warnings script disabled. I just checked with a couple of other PCs at work and I get the error with IE6 and a couple of other machines running IE 8. Looks like RCU made some updates which got their java scripts to loose compatible with IE or may be microsoft issued updates which got IE to mess up compatibility with this type java script.
I know it works in Firefox. With this thread RCU will take notice and fix this issue.
Banned
I think IE update. we made no changes to the js code. it works in safari and firefox ok. IE8 is choking. I've been working on finding an alternative mouseover tip today
