How connect tube, LANDING GEAR?
Anyone has a diagram how install LANDING GEAR ON EUROSPORT WITH JET-TRONIC ELETRONIC VALVES, LG AND BRAKES?
Thanks everbody friends!
RE: How connect tube, LANDING GEAR?
You can also have 2 air tanks and 2 separate air systems:
1-langing gear
2-brakes and gear doors
Then if, for example, you have a leak in the brake/ door system, the gear will still come out through the doors. You can also use more air pressure for gear and less for brakes to prevent locking wheels. But in a model like a Boomerang one air system is enough.
TP.
1-langing gear
TP.
