Robart hinge install idea
My Feedback: (22)
I used small O rings as spacers while installing the Robart hinges on my ailerons today. It worked great it keeps the glue out of the hinge and gives you the proper spacing if you need more you use two O rings. When the glue dries you can cut or pry them off , or leave them on the hinge. You only need to use them on one side of the hinge.
RE: Robart hinge install idea
ORIGINAL: figueroa
Thanks and best regards,
ORIGINAL: extra 300
Great idea indeed!! Do you also have a methode to align those hinges and prvent them to rotate avoiding friction/binding if their axles are not perfectly aligned??
My Feedback: (24)
I've been using a similar method for years but instead of orings, I use a piece of tygon tubing cut to the correct spacing length. Not only does it set the perfect surface spacing but it also keeps the glue out of the hinge joint. Once cured, simply cut off the tubing.
another way to do it is I take and cut vinyl gloves to approx 1 in square peices and place over hinge and glue in keeps the glue out of the hinge joint when glue is dry just pull off i do this after i have hinged the flap, rudder etc and i know the hinges are properly aligened and not binding
Arden May
Arden May
My Feedback: (22)
Thanks Eric,
The wings are ready for servo's , I got the control surfaces hinged and installed in less than two hours.
Just need to do the rudder.
Regards.
Jose
Regards.
Jose
Hello Jose:
Great idea, thanks for show us.
Saludos desde España.
Carlos.
__________________________________
http://cmjets.blogspot.com/
Carlos.
My Feedback: (22)
ORIGINAL: cmjets
Hello Jose:
Carlos.
Hello Jose:
Carlos.
My Feedback: (90)
ORIGINAL: A MAY
Arden May
Arden May
