More throw needed on U CAN DO 60
How far can I choke up on tail horns ( rudder and elevator) and not risk flutter.
I am using the long stock servo arms and control horns. With 4 40 rods and heavy connectors .
My Feedback: (21)
OR
RE: More throw needed on U CAN DO 60
like delman said you need longer arms. One more thing you could do is drill a new hole in the horn that is lower. If you do not have the clearance to do that then you will need new arms.
My Feedback: (84)
WI
I would not move in more than ¾ of an inch in on the horn and 1.0 inch or 1.25 on the servo. Best is 1 " servo to 1" surface. If you have flown the UCD and think you need more throws than what the manual states I would check the CG. My UCD’s CG is 6 inches back from LE (move the CG back ¼ inch at a time until it handles the way you want). My plane will turn on itself at slow speed with all surfaces 45 degrees. I use 4/40 Central Hobby carbon push rods and Sullivan steel horns and Dubro servo arms. I also hard point the sufaces with a wood dowel and the horn / screws will not crush the soft wood.
