esc + motor
02-21-2010, 04:40 PM
esc + motor
would it be alright to use a 18t motor with a 20t esc thanks in advance
02-21-2010, 04:43 PM
RE: esc + motor
The ratings are put in place for a reason, That being said you may get away with it but its a 50/50 thing. Remember the lower turns the more current draw. So give it a try and if it goes up in smoke buy a proper one.
02-21-2010, 05:14 PM
RE: esc + motor
so will it be best to check it to see that the esc isnt realy hot when using it
02-21-2010, 05:18 PM
RE: esc + motor
You have the right idea, Hook it up and run it checking the temps of the esc every few minutes.
02-21-2010, 05:23 PM
RE: esc + motor
thanks for the replys mate A+
02-22-2010, 04:20 PM
RE: esc + motor
Bad idea.The current draw will destroy the esc.</p>
