What is it exactly ?
Old 02-26-2010, 07:06 AM
Clutch Cargo
My Feedback: (69)
Clutch Cargo's Avatar
Default What is it exactly ?
Does anybody know what Top Flite LustreKote Spray Flat Clear is exactly ?
Is it a Lacquer ? Can it be top coated on all other paints and finishes with out damage ?
Thanks for help !
Old 02-26-2010, 11:24 PM
Campy
Campy's Avatar
Default RE: What is it exactly ?
I do not know EXACTLY what it is, but I can tell you it is lacquer based. Unless you are using Lustercrap under the clear, do a test panel FIRST (better to find out on a test panel than the plane).
FWIW - Most auto parts stores sell a clear ACRYLIC ENGINE ENAMEL. I have found this stuff to be compatible with MOST paints and is fuel proof for 10% nitro.
Old 02-27-2010, 09:14 PM
chemie
chemie's Avatar
Campy: are you recommending the automotive now vs the blue miniwax polycrylic?
Old 02-27-2010, 10:46 PM
TFF
Put Lustercoat on top of the wrong paint like an enamel and it will be just like paint stripper. Test before use.
Old 03-01-2010, 08:12 AM
dant-RCU
dant-RCU's Avatar
I have used it over cured Behr exterior latex with no problems. I have used it over Krylon with no problems.
I use it to fuel proof and seal computer generated decals - both ink jet and dry (ribbon) inks with no problems.
Trick is to spray light coats (2 or 3) rather than one heavy coat.
However, for my last painted project I used Varathane Diamond Floor Finish water based poly-u over cured Behr latex
and it is working out just fine.
Works for me.
Dan
Old 03-01-2010, 08:46 AM
Clutch Cargo
My Feedback: (69)
Thanks to all that have shared info .
Greatly appreciate it !
Old 03-01-2010, 08:50 AM
Clutch Cargo
My Feedback: (69)
Dan, you mention using Krylon paint with the Top Flite Flat clear over it.
Which type ? I think there are many to pick from (Krylon)
- Jim
Old 03-01-2010, 03:49 PM
stevenmax50
Hi guys.  I have painted 1 model and I am about ready to paint my second one.  On both models I covered with koverall and then Minwax Polycrilic.  I then painted with paint the local auto parts store mixed for me.  It is an acrylic enamel.   I find it to be fuel proof to 15%.  I have not used a top/clearcoat because my finish is a high gloss already, and is very hard.  I am interested in seeing if a clearcoat will give me more of a high gloss.   Auto clearcoat is very expensive.  At least, I have not found any that I can get in a small quantity.
I also read one of your postings where you applied a poly over the paint?  Did you do that in place of a clearcoat?
 And I have never seen a blue minwax poly.  Is that like a colored dope?
