primeing 1.20 ax
primeing 1.20 ax
Left the cowl off to break in my yak 54 with a 1.20 ax in it ,now when i put the cowl back on i cant get my thumb over the carb to prime it!! Any secrets of what to do ?
My Feedback: (9)
RE: primeing 1.20 ax
Yes, do the muffler. That's how I do mine all the time. You can also get a cork to put in the carb. Flip it with the cork in, remove and start. The little plastic caps from a glow driver work well for this. Just put a dowel in the end so you can grab it and put the cap round end down in the carb.
David
David
IL
Had the same problem with my OS BGX-3500 on a Midwest Extra. Finger over the muffler works well, or as stated earlier, a cork the right diameter to fit inside the carb. also works.
