SIG Komander
SIG Komander
Old 03-07-2010, 09:38 AM
Bill Diedrich
Bill Diedrich's Avatar
Default SIG Komander
Living overseas when this kit was availalble, I never got to see one
or build one. My question is was the plane built on printed fuselage
sides or were plans supplies with the kit? If plans were supplied does
anyone have a set that they can copy for me?
Many Thanks,
Bill D.
Old 03-07-2010, 12:18 PM
vpresley
My Feedback: (162)
vpresley's Avatar
Default RE: SIG Komander
Hi
Oops, that was for my SIG Kougar. Have a Komander coming in the mail. Will let you know when I get it, if someone else has not posted the answer.
Vince
Old 03-07-2010, 02:04 PM
landeck
I built one back in the mid 70's and, IIRC, it had printed sides and a foam wing.
Bruce
Old 03-07-2010, 07:18 PM
Bill Diedrich
I spoke to one of the "OLD" guys at the field today and asked about it
best he could remeber was the Mk 1 had the printed sides & parts and
the MK. 2 had die-cut parts, but couldn't remeber if it had plans or not.
The foam wing is still available from Eureka Aircraft in, Eureka Springs, AR.
Bill D.
Old 03-08-2010, 11:45 AM
Bigc
I built one about twelve years ago and the fuse was built based in the printing on the balsa. There was a booklet supplied if I remember correctly, but
after 3 moves, I don't have it anymore. Was a good flying plane. Had an OS 46 in mine.
RobertC
Old 03-08-2010, 03:09 PM
TCraft Lover
I built two of these but don't remember if they Mk1 or Mk2. They printed balsa, sheeted foam wings and a manual only. Build was straight forward. The Kommander is a great flying bird. I had a Fox .50 on mine.
Dave
Old 03-09-2010, 08:05 AM
rogue-RCU
I have one waiting to be built. It has printed sides on the fus and foam wings.
Old 03-09-2010, 09:42 AM
TCraft Lover
Hi Rogue,
I'm sure you will enjoy the build and I know you'll love the flight characteristics. Can be reasonably aerobatic. The stockLG instalation is a might weak so you may want to beef it up a little. Enjoy it.
Dave
Old 03-09-2010, 11:51 AM
OldRookie
My Feedback: (13)
The Kommander kit I built years ago, only had an instruction manual with it. No Plans.
Greg
Old 03-09-2010, 03:19 PM
TCraft Lover
I'd love to have another Kommander kit. They built easy and flew great. fSome guys eliminated the factory main gear and installed ply and a set of aluminum mains on the lower fuse. They would have to be short ones though.
Old 03-10-2010, 03:48 AM
vpresley
My Feedback: (162)
vpresley's Avatar
I think they called that a kavalier ! At least it real close.
Vince
Old 03-10-2010, 07:53 AM
TCraft Lover
Kavalier and Kommander are similar but Kommander is larger. Point being that the Kommander has wing mounted mains which are known to pull out on rough landings. Sometimes even not so rough landings. Having this reputation some builders added 1/4" ply on the belly and a set of aluminum main gear to get away from this tendency. I think the Kavalier kit is still offered by Sig.
Old 07-05-2010, 09:25 AM
rambler53
My Feedback: (494)
http://www.hobbyhorse.com/sig_kavalier.shtml
I found this to be the best second plane I've ever flown.
You can throw a .46 on it and really belt out some speed too.
The wing is excellent and the plane is very strong.
Are you still looking now that 4 months have passed?
Old 07-05-2010, 12:29 PM
tailskid
My Feedback: (34)
tailskid's Avatar
I flew the heck out of the Kommander...and that wide track landing gear made landings beautiful. Never did have any problems with the gear coming lose. Just used a lot of epoxy I guess .
Old 07-05-2010, 09:40 PM
tweedy
tweedy's Avatar
I built one in 1975, silk and dope, with a OS Wankel 30, it fit perfect in the cowl, used an undersized spinner that allowed cooling air to get to the engine. I was always worried about the long gear legs, but they never failed, and I was flying off pretty tall grass at times, the Wankel was not really enough power.
Richard
Old 07-05-2010, 09:42 PM
tailskid
My Feedback: (34)
tailskid's Avatar
That plane would look great in a camo color scheme - WWII vintage
Old 07-06-2010, 06:39 AM
landeck
ORIGINAL: tweedy
Richard
I built one in the same time frame. I had an Enya .45 in it and it flew great. I too was flying off grass and never had a problem with the long landing gear.
Bruce
Old 07-06-2010, 09:15 AM
WORNBOOTS
My Feedback: (33)
WORNBOOTS's Avatar
Here is a excerpt from the box referencing the printed wood assembly, along with die-cut parts and manual (From a early kit Not MK-II)
Plans were not used, and most of the construction is fairly simple and straight forward.
The Manual is very comprehensive and completely covers the entire assembly, it's also geared towards the low-time builder.
Old 07-08-2010, 07:33 AM
AA5BY
Also build one in '75 and used the just released Enya .40, which flew the plane with plenty of authority. It served me as both trainer and intermediate. No problems with landing gear. Also silk and dope.
An interesting aside is back then, one of the 3M spray adhesives was foam friendly and sheeting a foam core wing was a piece of cake with the spray adhesive. A wing would build up really fast, and they were strong albeit slightly heavier than a built up wing. The Kommander had a generous wing for a .40 size plane and with the wash out had good flight temperament.
Old 07-08-2010, 08:36 AM
ckangaroo70
My Feedback: (51)
ckangaroo70's Avatar
I actually have couple sets of Komader plans. I would be happy to send you a set if you still need a plan.
Old 07-08-2010, 09:23 AM
blw
blw's Avatar
ORIGINAL: rambler53
I've built a Kavalier and have one NIB. They are excellent models designed by Claude McCullough.
The Kav is one of those kits that are easily modded. One company offers foam cores for the wings.
The Komander sure is good looking. I also have the plans filed away somewhere. The box art shot is identical to the Kavalier picture. They were probably shot on the same day.
Old 07-08-2010, 11:39 AM
AA5BY
IIRC the Kavalier was a later release... perhaps a few years later.
Old 02-24-2014, 06:27 PM
CVN70VET
what is a complete Sig Komander kit worth. I have to sell at the right price
Old 03-10-2014, 12:39 PM
Red7fifty
My Feedback: (73)
If you have a NIB, with Shrink Wrap, I will pay a pretty penny....(more actually) for a cherry example.
But, I'm still interested for a nice condition NIB kit.
Old 10-30-2014, 12:38 PM
robbtennis
Hello gents, I'm looking for a Komander canopy since I recently landed my show quality model in an oak tree. I am beginning to reconstruct her with modifications inc retracts and alternative tail configuration since I never liked the original. I plan to post progress here so stay tuned and please advise me if a canopy happens to cross your path. Thank you in advance!
