Broken E-Savage Universal-shafts
In the last month, I've broken two universal shafts doing nothing more than running around the back yard. To be fair, there were a couple small jumps but nothing big. Are the shafts known to be a weakness of the E-Sav. I'm running stock motors with a Novak EVX-2 and Lipos. I would think that this would not be too much stress for this vehicle but apparently I'm wrong. I didn't want to spend $100 on Kershaw CVD's but at this rate, it might make sense. Any thoughts? Any alternatives to Kershaw designs?
WA
RE: Broken E-Savage Universal-shafts
Im gonna tell you to do the same thing everyone told me to do when i was breaking revo axles left and right.......loosen the slipper. Did it help me? No. But just thought i would mention it because you know someone else was going to lol
Thanks for the replies. So, it looks like it's not just me! I have two older E-Maxx's that I converted to brushless. I thought it would be cool to keep the E-Sav water resistant with the EVX-2 and brushed motors but it gets pretty annoying when i can't even get a few full runs on this truck without breaking a shaft. Maybe I will upgrade to the Kershaw CVD's. I just feel like the stock shafts should be built more than strong enough to handle the power I'm running through it.
I'm pretty sure the Nitro's parts aren't compatible with the E-Savage. I'm looking at possibly modifying some Traxxas shafts. I'm not sure if it's possible but it looks like it could work.
VT
no they aren't i've heard some mod about revo shafts i tihnk, maybe slayer, but i think the kershaws are your best bet, and shimming the diff
the lug
the lug
My Feedback: (31)
KY
There are certain Traxxas driveshafts that will work, and are a cheap upgrade. It will help keep your driveline together, and the E-Savage is known for its weak driveshafts, and differentials, so with much power at all, as you have seen, it needs some TLC to stay reliable.
I have a question for you that is a little off topic... Did you run the E-Savage ESC before you went to the EVX? Did you notice any difference in run times when you did the swap? Thanks
Eric
Eric
Eric,
I never used the original ESC. I bought the E-Savage as a roller and installed the electronics that I had. With 5200mah lipos, the EVX-2 gets about 20-25min run times before the low voltage cut-off kicks in.
Jim
Jim
Thank you for all the replies. Somehow luck is on my side with this issue. A while back, I bought a used E-Maxx 3906 on Ebay. It came with steel cvd's. However, the suspension arms were shorter than the standard 3906 arms and therefore the cvd's were shorter as well. I decided to put the longer 3906 arms and new cvd's on it to give it a wider stance and better handling. I tried the old cvd's on the E-Sav and they are a perfect fit! (Maybe i should go play lotto) The only thing I need to do is get some 6 x 15mm bearings since the E-Sav and E-Maxx axle carriers are different. I also ordered some shims for the diffs and I'm hoping that this will take care of the E-Sav weaknesses. The only thing that may still need some upgrading is the center drive shafts. Thanks again for all the great suggestions and guidance.
