.06 Mod Pinion
Old 04-20-2010, 08:53 PM
kuppler
kuppler's Avatar
Default .06 Mod Pinion
Where can i get a .06 Mod Pinion??
48 Pitch??
links??
i think someone posted this before but i cant find the posts...
Old 04-20-2010, 09:13 PM
ehroof
Default RE: .06 Mod Pinion
Pede is the man, get in touch with him.
Old 04-21-2010, 07:50 AM
genitor
Robinson racing pinions 48p metric http://cgi.ebay.com/Robinson-Racing-...item563b5224d2
These are supposed to be steel alloy but i find they only last a little longer than the aluminum tamiya ones.
The plastic spur in my mt-10 seems to be very hard and wears out pinions quickly.
or tamiya av pinions, http://cgi.ebay.com/Tamiya-50354-RC-...item1e5b47f1b5
Old 04-21-2010, 08:34 AM
kuppler
kuppler's Avatar
so the 6 mod is the same as the 48 Pitch Metric ones???
Old 04-21-2010, 11:36 PM
genitor
yep, have one in my mt10 right now.
Old 01-08-2013, 08:07 PM
DVUSHELI
48P is NOT the same as MOD .06.
I'm sitting here with a Tamiya TA05 M-Four and a bunch of 48P pinions and the .06 18T it comes with is bigger than the 48P 18T I already had.
Old 01-08-2013, 08:35 PM
Haddi Taha
Haddi Taha's Avatar
You can't use 48 pitch with 0.6 mod. There is a big size difference<div>
</div><div>Here are some high quality 0.6 mod pinions</div><div>
</div><div>http://www.robinsonracing.com/catalog/32pitchpinion.html</div><div>
</div><div>scroll down to the 0.6 mod section</div><div>
</div><div>Yeah Racing also sells 0.6 mod pinions but they arehard coated aluminium, not good against a steel spur but fine with a plastic one</div><div>
</div><div>Novak also sells 0.6 mod pinions, not sure how good they are, its says aluminium too</div><div>
</div><div>http://www.rcmart.com/pinion-spur-motor-gear-motor-gear32-pitch-05061-c-1293_1519.html</div>
Old 01-08-2013, 08:38 PM
DVUSHELI
Now is that mod 0.6 OR .06, cause they would be different. No?
ORIGINAL: Haddi Taha
Old 01-08-2013, 08:45 PM
Haddi Taha
Haddi Taha's Avatar
ORIGINAL: DVUSHELI
I've never heard of any 0.06 mod in rc applications, the teeth will be super tiny.
0.6 is used in many Tamiya and Kyosho 1/10 cars. I discovered my HSP 1/10 Touring Car had 0.6 mod too!
<br type="_moz" />
Old 01-08-2013, 08:57 PM
DVUSHELI
That's what I found on Tamiya's website for the 18T that came with this M-Four kit.
I may just change it over to 48P gears using HPI or Robinson spurs. Hopefully they're the same bolt pattern for the hub.
Old 01-08-2013, 09:04 PM
Haddi Taha
Haddi Taha's Avatar
ORIGINAL: DVUSHELI
If you find a 48 pitch spur that fits, it will work. But its easier and cheaper to just buy a 0.6 mod pinion
<br type="_moz" />
Old 01-08-2013, 09:13 PM
DVUSHELI
Well, the 0.6 ones look a bit too big in the tooth, and I already have an abundance of 48P pinions from previous cars. I'm only inquiring because this car runs a 380 size motor and after taking a short drive today, the brushless Novak 380 I have was at 125F degrees. A bit hot I think for just a few short burst, so I may need to gear it down some. Rather buy two new 48P spurs than hunt for a difficult to find pinion. Thanks for those link though, I'll still take a look at them.
ORIGINAL: DVUSHELI
<br type="_moz" />
