rpm knuckles
rpm knuckles
part number 80035 are not a direct fit for the mgt 8.0. You must order http://www.rpmrcproducts.com/product...s.htm#Setscrew and I can't get the toe out the rear. plus the bearings are thicker and the axle pin is a pain to get to go in. when they came in they said they fit the t/e-maxx. I checked tower and rpms web sites and they are the right parts called for the truck
RE: rpm knuckles
I ground one side of the pin slightly flat and put that side towards the bearing. It goes in much easier now and doesn't seem to have weakened it.
