Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Best way to remove aluminum servo horn?
Old 05-30-2010, 01:11 PM
wantboost
Default Best way to remove aluminum servo horn?
whats the best way to remove horn with out damaging it or the servo?
Old 05-30-2010, 01:18 PM
proanti1
proanti1's Avatar
Default RE: Best way to remove aluminum servo horn?
You got one stuck on a servo? Did you put the wrong type on? Never had that happen... maybe try prying very lightly underneath it with a small flat head.
Old 05-30-2010, 03:25 PM
i8tweety
i8tweety's Avatar
You haved a couple choices:
(1) use two blade screwdrivers and gently pry with even pressure with a screw driver on opposite sides of the servo horn
(2) thread a longer bolt into the servo spline such that there is a gap between the screw head and the servo horn. If the servo horn is a single arm, hold if fast with pliers (or vice grip), using tape or rubber band to help minimize any marring of the servo horn and tap the bolt with a hammer repeatedly to remove the horn. If the horn has 4 arms or 2 arms opposite each other, you can also rest the servo horn in the open jaws of a vice when tapping the bolt.
