Li-Ion/Li-Poly Chargers...which one for Rx packs?
KS
Ive been looking everywhere for some information.
I fly some indoor electrics, .40-.60 size nitro, and giant scale gassers. Im getting ready to go to Li-ion Rx packs, and want to know what would be a good charger for my Li-ion Rx packs and the smaller Li-poly packs that I use?
Thanks!
Jsflyer
Thanks!
Jsflyer
KS
RE: Li-Ion/Li-Poly Chargers...which one for Rx packs?
Is that the same as this: [link=http://www.hobby-lobby.com/b6_pro_80_watt_balance_charger_discharger_for_1_6_ lithium_cells_rc_battery_charger_528696_prd1.htm]Hobby Lobby[/link]
I think you will like this new charger: http://hobbyking.com/hobbyking/store...dProduct=11668
Features;
Microprocessor controlled
Automatic charging current limit
Capacity limit
Temperature threshold
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~6.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 193g<div>This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, TURNIGY and any pack with a JST-XH adapter.
Note that you need a separate power suppy, as with most chargers.<br type="_moz"/></div>
Features;
Capacity limit
Time limit function
Data storage
Spec.
KS
Thanks for the heads up on the charger from HobbyKing...I did notice that you recommend their products an awful lot to just about anybody looking for anything... I would consider it more seriously if it had more reviews on about it.
It's a relatively new product, so you won't find many reviews as of now.
Yeah, I like the way Hobbyking gives us nice deals on everything [8D]
Edit: I must add that r/c products in my country are much more expensive. Reasons are tax and owners of shops that want to make too much money (that is not only my opinion, also many fellow countrymen complain about this). Even if you add shipping costs and import duties, many of the HK products are much cheaper.
PA
The HobbyKing/Turnigy chargers are great, I have two Accucell-6 chargers. They will charge Li-Ion, LiPo, and LiFePO4 cells. I just went to 2S A123/LiFePO4 RX packs, so the latter is coming in handy now.
