Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Pulse 25XT
Old 07-09-2010, 02:14 AM
dschroeder
My Feedback: (40)
Default Pulse 25XT
I picked up a Pulse 25 (electric ARF) i'm going to drop an old OS 40 4-stroke in it. first electric to glow conversion...any advice?
Old 07-09-2010, 06:17 AM
Mr Cox
Mr Cox's Avatar
Default RE: Pulse 25XT
I haven't flown that one but a 40 engine in 25 model plane does not sound right to me.
Would be better with a 25 two stroke or 30 four stroke I would think. The electrics are a bit weaker built and also lighter so there is no need to overpower them.
Old 07-09-2010, 07:50 AM
dschroeder
My Feedback: (40)
I also have a OS 26 Surpass I could try too...or if i go with 2 stroke i have a TT 25 Pro
Old 07-09-2010, 11:45 AM
BadSplice
BadSplice's Avatar
My understanding was that a .40 4 stroke would be about equal to a .25 2 stroke? I am in the process of putting a saito .45 into the Pawnee 15-25E and Im actually concerned it wont have Enough power...
Old 07-09-2010, 04:23 PM
Mr Cox
Mr Cox's Avatar
To me it is not simply about the maximum HP that you can get out of an engine, it also depends on what kind of flying you're after, so it is not that easy to give an exact "conversion formula".
I do not run 4 strokes myself but for sport use I think a modern 4 stroke 30 can replace a 2 stroke 25. The advantage is a more comparable weight and a larger prop swung at lower revs, i.e. a well behaving sport plane. If you looking for maximum power vs weight then I think you are better of with a 2 stroke anyway, at least in these comparatively small engine sizes.
The weight penalty of a 4 stroke 40 engine might make it fly like a brick while giving comparable power to a 2 stroke 25.
Old 07-09-2010, 07:18 PM
dschroeder
My Feedback: (40)
OS 25 AX 12.6 oz (with muffler) 9x5 10x5 prop
OS Surpass 30 10.4 oz (with muffler) 9x6 10x6 prop
OS Surpass 40 13.3 oz (with muffler) 10x6 12x6 prop
they all are pretty close within weight, i'm assuming my 26 4-stroke weighs approx the same as the 30 4-stroke...and that my TT 25PRO is comparable in weight to the 25 AX
Old 07-11-2010, 08:00 AM
CustomPC
CustomPC's Avatar
The .25FX is 10.8oz with muffler.
I would also consider the vibration levels that you might see with a 4-stroke. Many smaller 'e' models use lightweight servos that will likely fail with excessive engine vibrations.
Old 07-11-2010, 09:52 AM
dschroeder
My Feedback: (40)
i was going to run these servos
http://www3.towerhobbies.com/cgi-bin...?&I=LXN664&P=0
Old 07-12-2010, 07:10 AM
Mr Cox
Mr Cox's Avatar
That AX sure sounds heavy, a two stroke 25 engine shouldn't have to weight more than about 10oz.
My advice is to go with lightweight stuff all the way, i.e. 10 oz for the engine and keep the rest lightweight too. Magnum/ASP/SC .25 would be lighter and cheaper than an AX.
I haven't used those servos myself, but they do sound strong enough. Just keep the weight low and almost anything will fly...
Old 07-15-2010, 12:22 AM
proptop
My Feedback: (8)
proptop's Avatar
I put a Thunder Tiger .28 in a friends Pulse 25...it is a nice combination. I had to side mount it...cylinder at 9 o'clock position, in order to get the carb at a proper level to the center-line of the tank.
Had to remove a bit of material in the battery tray area to make room for the tank. After that, had to reinforce the same area to get strength back...and I laminated some additional 1/8" ply on the firewall.
I like the way the new TT .28 has both beam and firewall mounts cast into the case...it made it easy to just bolt the engine to the firewall.
The fuselage and tail structure is kind of light...don't know if the 4 stroke .40 would be a bit too much? I have a feeling that if you carefully beefed it up in the fwd. area (tank compt. ) and firewall, it should be ok. I have an O.S. .40 Surpass and could see it as an alternative to the TT .28
The wing is plenty strong enough, IMO...but the horiz. stab and elevators aren't all that strong...(seems to be a "family trait" because the tail feathers on my XT40 are a little wobbly too )
We also used Hitec 225 servos...
Old 08-06-2010, 05:08 PM
scooterinvegas
scooterinvegas's Avatar
I just picked up a XT25 today to put a OS 40 LA back into service. The LA 40 is not the fastest engine in the world, and didn't fly my superstar 40 with any authority. I just hate having a motor sitting on the shelf not doing anything. There is a ton of side thrust built into the fire wall, does anyone think there is a difference in side thrust setting between glow and electric? I'm going to mount the battery and maybe the tail survos in the back to offset the weight of the motor. Scoot
Old 08-06-2010, 09:02 PM
proptop
My Feedback: (8)
proptop's Avatar
You might want to cut back on the right thrust? The glow prop will be substantially smaller than the E prop...less P factor...less torque effect, etc.
The LA .40 should work well...let us know, aye [8D]
Old 08-27-2010, 10:22 PM
scooterinvegas
The firewall is set at 2 down and 3 right, that seems excessive for a low wing plane. My Ultra sticks have zero right thrust in them. Does an electric powered plane have to have more down and right thrust than an glow plane? I'm not comfortable starting out with that much angle for my glow conversion. I'm mounting an OS 40LA in it by the way. Its an old engine that I had laying around and wanted to use. It ran great with a 10x6 APC, but it was pulling a larger plane around. I might a 12x4 or 5 with the smaller plane.
Old 08-28-2010, 07:54 AM
Mr Cox
Mr Cox's Avatar
In principle a larger prop may demand a little more right thrust than a smaller one, but if you have ailerons then you can compensate using thoose too. Unless you're a pattern addicted flyer, but then I don't think you would ask here anyway. Also 2-3° is typically what one will get or remove with a set of washers so you could build as it is and then add washers later, to either increase or remove the built in thrust angles.
On the latest low wing conversion I did, it required more down thrust than it was set up for as an electric, think I have about 4° now rather 2° (haven't measure it after I tuned it for good flight).
I wouldn't worry too much about it, it will fly as it is without any problem and it will have too tuned in flight anyway.
Old 09-07-2010, 11:24 PM
scooterinvegas
OK, I have time to get back on the conversion, and the LA 40 is just to long as is. I have checked smaller engines, and there all to long. Im going to cut 1.125" out of the firewall to mount the engine back where I want it. What did some of you do to overcome this problem?? I could mount the engine as is, but I would have to move the cowl forward 1.125" and it just looks wrong. Way to long out front.
Old 09-08-2010, 09:23 AM
Mr Cox
Mr Cox's Avatar
On the ones I have done (not the Pulse) I modified a plastic hayes mount so that the engine could be positioned really close to the firewall. Do you have any pictures of your problem?
