Need help on G20
SC
Need help on G20
I have a G20EI with a bent prop hub. Can anybody tell me how to remove the hub. I know it is on a taper but I can't get it to release.
Dennis
Dennis
RE: Need help on G20
ORIGINAL: dennis18
Dennis
Dennis
Karol
SC
Thanks guys.
This is a freinds engine and I finally checked the manual on line and it shows using a puller. I have already pulled and straightened the prop shaft but the hub is out almost .020.
I'll try a puller tomorrow with a little heat and see what happens.
Dennis
Dennis
SC
I got the hub removed today and it appears like I have a bent hub. I'm also worried about the crank. I get .005 T.I.R. on the grank right behind the taper. That seems like a lot, I was expecting more like .001/.002. What kind of runout should I see on the crankshaft?
Dennis
Dennis
DC
right behind the hub is right at the edge of the front bearing...should be .000 there...Must have been some crash to bend a crank that close the the bearing....
If you're checking it in a lathe chuck there is a problem, the crank is twisted in the center...you need to check it using a 1/2 or 3/4" steel block bored for a very close fit to the crank diameter ...Stick the tapered end of the crank through the block and indicat the end of the tape, it will most likely be .000...Indicat the other end of the crank without taking the crank out of the block..Any runout there is twist in the center..Block the web and correct the twist with a hammer...Slowly....
Try to get ,000, less that .002 should be ok...
a REALLY bad crash can bent the taper in the aluminum hub....
The stud can be perfect and will still show runout when tightened into the hub, it's the nature of the design...You can sometimes get the stud to .000 by gentle tapping when the whole thing is put back together...
SC
I clamped the engine to an angle plate on a granite surface plate and used an indicater to check the crank tip right in front of the front bearing. It sounds as if I need to remove the crank and check further right?
Dennis
Dennis
