Electrifly battery. Do I have to charger through the balancer?
I've got a couple of ElectriFly LiPo 3S 11.1V 910mAh batteries for a Helimax 400 cp....They give you a small charger with it but it says clearly in the instructions to only charge through the balancing plug not the larger Deans plug....I do have a balancer that I can use with my Accu cycle charger.........So, I'd like to use my charger and balancer if all possible........Is this ok? All the other lipos I have used it the past ,I've charged through the deans plug and their fine..
MA
RE: Electrifly battery. Do I have to charger through the balancer?
I started the same way. It should be fine. The charges they send you can't pump enough pwr to charge the other way. Just run your charger on balance. Make sure all your charger settings are correct then let her go
