Is it possible??! Stinger Drive with Homelite Engine
Old 09-04-2010, 02:38 AM
spede18
spede18's Avatar
Default Is it possible??! Stinger Drive with Homelite Engine
I have a homelite I am trying to use with a stinger drive that is meant to use rounded flex with welded shaft.
Is there a way to make this work with my homelite?
Old 09-04-2010, 02:41 AM
martno1fan
martno1fan's Avatar
Default RE: Is it possible??! Stinger Drive with Homelite Engine
You can get welded shafts with square ends to fit the homies,you may need to have one made to the correct length but im sure whhobies do them to order.Or you can remove the clutch and buy a collet with the correct threads to fit the output shaft and your good to go.I used a cmb.90 collet on a weedy engine after removing the clutch,worked fine.
Mart
Old 09-04-2010, 03:10 AM
spede18
spede18's Avatar
ORIGINAL: martno1fan
Mart
Mart I'm glad to hear from you!
I figured you might have an idea, everyone has been telling me there isn't a way.
Where did you get the collet from?
I contacted tony to see what he could do for me I'm sure I'll hear back from him soon but I figured there was a collet drive and someone said there was but wasn't sure if it was made anymore
Old 09-04-2010, 05:00 AM
martno1fan
martno1fan's Avatar
The collet i used maybe wont work on the homie im not sure,depends what thread it has,i think the cmb.90 one i used had m8 thread.
http://cgi.ebay.co.uk/COUPLING-FLEXH...item1c1551da07
Old 09-04-2010, 12:59 PM
rangerfredbob
My Feedback: (13)
his homie has 3/8-24 threads that end about 2" in front of the flywheel so either the threads need to be reamed further down the crank and tap a standard weedie collet for the larger threads or the crankshaft needs to be changed.
Old 09-04-2010, 02:18 PM
spede18
spede18's Avatar
Istill think there is a way to use a brass sleeve, couple people seem to be using this instead of a ferrule.
