walkera 59# help and advice needed
Hi i usually play with nitro and TNT etc but i came across a walkera 59#. The box has 59#/60# on it but looking at the pic on it, it shows two varients, 59# and a 60'#. I have tried like mad to get spares for this 59# but can not find any world wide.
the size difference are rotor diam 59# 600mm 60# 605mm
the rest is same spec except gyro is placed different and main body frame is silver on the 59# black plastic or metal on the 60#
Also it has the standard RK-400sd motor, WK-B20A speed controller, and WK-G006 Gyro. It says you must use Ni-MH 12v batteries and that Lipo ones may damage it, any truth to this?
So any one know of this heli 59# and is it classed as any other or are parts interchangable between the 59 and 60
any help or comments much appreciated.
steveyg
steveyg
