covering foam aircraft
QC, CANADA
RE: covering foam aircraft
Covering as in???
What do you mean? final covering? coveirng for strength? sheeting?
What type of plane is it, it's intended purpose? etc..
we'll need some more info...
Is this a secret project? You sure don't seem to want to give out any info.
If it's a park flyer, just paint it with water based paint. If it's a scale model, sheet everything, then fiberglass it. If it's a combat model, cover it with packing tape.....
I can go on, but I doubt this is helping much. How about some more info now?
Dennis-
Dennis-
My Feedback: (17)
NY
What i want to cover is a foam chipmunk that will be powered by a 15 glow engine .I want to cover for cometic reasons and to fuel proof the foam. can i use silk with epoxy or will that melt the foam.
It seems you are reluctant to give too much away, so I will answer your specific question.
Epoxy will not melt the foam.
Ed S
Ed S
