New 3speed vs stock drive shaft
MI
RE: New 3speed vs stock drive shaft
Im replacing the stockers with Hot Bodies mt cvd's, heres a couple of comparison pics. the HBs are nice, Ive been running their cvds as a replacement for the stock HD dogbones after I twisted one back in the spring, so far they are holding up great.
Greenghost, I recently went to upgrade the SS heavy duty dogbones for the MIP cvds' but balked at the price. I went for the HPI center driveshaft upgrades but am stuck on which diff to wheel cvds' to get. Would you say the Hotbodies ones are a decent alternative to MIP?
MI
ORIGINAL: Scouser
also, if you do run any cvd's use red loctite on the set screws, not blue.
Any of you guys know where to find a cvd to drive a Truckzilla sport center rear Im open to any suggestions. If I lived close to a good hobby shop I would take my ruler and find one if it exists :P. The over all length is 125mm or because I have a new set of MIP couplers I just need a shaft that measures 110mm to the pin.
Any help would be appr3ciated
ORIGINAL: :Green:
I got more torque than I had with the stock mill and two speed, thats for sure.
edit-Rear I assume? Left or right side?
MI
ORIGINAL: gravedigger
What were you doing when it let go? I've had my 3spd for a week now and I haven't had any issues at all and I've had the hammer down every time I've brought it out.
ORIGINAL: :Green:
just running it easy, well kinda easy....Mine must run better than yours.
the 4.6 wasnt exactly a stock set up engine either., but anyways it was the rear center stock one that came with my SS kit.
also I have twisted a rear left or right cant recall what side dog bone too, a wile back this is an old thread... it was the stock HD chrome ones.
KS
when they make the dogbones HD they become brittle. im using a black one to replace a broken silver
CVDs are a great upgrade
MI
I still have the stock HD bones on the front and the chrome is peeling off at the necks and they are starting to twist, Ill have to pick up a set of the black ones for a try.
