TC3 Pinion Gear Mesh Adjustment How??
Hey guys, just got my TC3 I think the mesh is off because it slips sometimes and sounds horrid. Can someone tell me how to adjust the gap? Thanks
WI
RE: TC3 Pinion Gear Mesh Adjustment How??
first off you loosen the top part of the motor mount, an then simply turn the motor as its mounted to an adjustment cam, once its at where you want, it just tighten the mount back up.
