Telemetry Tach on DLE20
Trying to use the Spektrum RPM sensor, but its supposed to attach to the back of the case to sense the crank pin, but that wont work on the DLE, so need other suggestions.
My Feedback: (17)
RE: Telemetry Tach on DLE20
Here is what I did. Just use a "Y"connector between the sensor on the prop hub and the ignition module and plug this lead in. I made it from a Spektrum satellite extension.
