FOX upgraded <K-60G>
And finally from the dream closer to the turbine white fox.
Flight propeller white fox had provided very valuable flight data, although not yet decommissioned white fox, looking forward to the flight data can make the upgraded turbo white fox Basket days in flight more elegant, more durable.
Just received a cute K-60G, the dream has come true feeling of the first step, because all the upgrades planned all around her, and now she does the equipment in accordance with the planning!
RE: FOX upgraded <K-60G>
Currently Fox counterweight to complete than the previous generation of electric propeller lighter one kilogram body weight of 9 kg, so the original hard on the lever principle is useful drops! A relief.
When coupled with fuel 1200.cc, the body weight on the previous generation of electric propeller similar fox about 10 kg, but not identical, is ....... fuel consumed, the aircraft will be more light weight.
Will the V stab be ok with the heat from the turbine? Just wondering whether it would be worth using some Aluminium strip along the leading edge of the V stab just in case it starts to irritate / break down the resin etc!
Hi Marcelo
This is the introduction 4 m fox glider website, I do not know his factory name, but I will try to tell you to find out.
[link]http://www.icare-rc.com/fox_400.htm[/link]
Regards
Tony
Regards
Tony
I considered the worst case, it means a double splint security measures will eventually make the ground running quiz.
Thank inform.
Regards
Tony
Thank inform.
Regards
Tony
4 m fox glider need pay 900USD.
If 4 m fox glider for jet Main beam to be changed to carbon.Servos need to use force to ensure safety of 10-20 kg.
If you can return data monitoring engine operation is complete security preparations.
Regards
Tony
Regards
Tony
All prepared in accordance with the schedule fox dry weight of 9 kg, all prepared full of oil weighs 10 kg, weight loss success, compared to the previous generation of white fox 1850 gram weight reduction, wing load burden has been in the category of experience, waiting for test flight ........
Hello,
FYI:
http://www.topmodelcz.cz/index.php?&...detail&id=6591
Had a great success with converting this one with K-80 turbine.
Good luck...
Babish.
FYI:
Good luck...
Babish.
Thanks Babish.
Fox successful maiden flight yesterday, enjoy watch videos.
4M JET FOX Maiden
[youtube]http://www.youtube.com/watch?v=6jozQnjSx7k&feature=youtu.be[/youtube]
4M JET FOX Maiden
