Dle 30 response
Dle 30 response
Hi,
I was flying a Dle 30 on a Sbach 300 GW on Sunday. In the previous week we had set up the throttle curve by the onboard tach. Subsequently I had added a bit of down thrust to the engine and installed a Jtec Pitts wraparound muffler instead on the stock to allow cowl fitting. This changed the throttle trim slightly. So on Sunday we changed the multipoint curve to get a more smooth response but we didnt use a tach this time. There was a lot of rain on Sunday, so I couldnt do much flying. Basically, I just did a couple of low passes. Also due to the weather, we couldnt set up the airplane properly either. During the low pass, I felt the airplane nearing stall and added 3 clicks of power. However, nothing seemed to happen and I had to add more power to fly out. Now, I am not sure whether this was a throttle setting problem or that I am more used to glow engines. I have the engine with its needles still set at factory. Just wanted to know why is the engine response so retarded? Is it a throttle setup issue or a engine characteristic for the dle30?
Ameyam
Ameyam
RE: Dle 30 response
Ameyam,
Needles still set at factory settings?
Step one. Start engine.
Step two. Adjust needles.
If you have been getting by to this point running the factory settings (that are intended to have the engine set close enough to start only) it's been purely luck. The factory does not intend to set those needles to the point the engine can be flown using them.
