Question re electric cars/trucks...
I have three lipo batteries intended for airplane use; specifically, this one:
http://www.horizonhobby.com/products...ec3-EFLB21003S
Can these be adapted to a current-production car/truck/etc. RTR or kit?
IL
It can, but depends on the vehicle. 2100 mAh isn't a lot of run time for ground vehicles (you tend to see a lot of 4000 or 5000 packs used). I see that it's a 3s pack, which is plenty of power in a 1/10 (overkill in a way) - so you'd want to be sure your ESC can handle 3s.
Also, the pack is rated at 20C, which seems on the low end of things for ground stuff - that's only what....42 amps (is my math right?) - so you'd want to be sure your ESC/motor combo isn't demanding more than that, or you'll heat that pack up quite a bit and may damage it straight away.
In short, you'll have to do some homework on the electronics to be used (motor/ESC) - find out how many amps your pack needs to supply.
