RCS 1000 module
Old 12-27-2020, 08:45 AM
Skymaster337
My Feedback: (10)
Default RCS 1000 module
Does anyone have a RCS 1000 ignition module they can tell me what wires are attached where on the 10 pin block on the side of this module. There should be some wires coming from the hall effect sensor that's screwed into the crankcase block of the motor going to the 10 pin block of the module. Colour and where the wires pin into the block is what I'm after to make up my own harnesses. Pictures would also be helpful if you have a RCS motor using the 1000 module. Thanks in advance.
Old 09-12-2024, 10:36 AM
pjwright
pjwright's Avatar
Default RCS1000 Ignition Connector
In case you still need, or someone else is looking, this is how the wires come to the RCS1000 ignition module from the Hall sensor inside the engine (26cc) case. White on top, then brown in middle, and green - occupying the top three pins on (what APPEARS to be) the "outer" row (away from the module).
PJ
Best guess which row the wires in the plug go to
RCS1000 Ignition Connector - White wire is on top, then brown and lastly green coming from Hall sensor inside engine (26cc) case.
