HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
motor won't fit ??
Old 04-08-2004, 09:13 PM
rclement
rclement's Avatar
Default motor won't fit ??
I am putting together an SS and wanted to use my Force 26 instead of the HPI but the Force doesn't have the same bolt pattern as the HPI. I checked to see if my Picco Outlaw motor would fit and it doesn't even fit over the motor frame that comes with the kit. What do yall use to fit the different motors in?
Old 04-08-2004, 09:45 PM
cemeb4dk
cemeb4dk's Avatar
Default RE: motor won't fit ??
the force motor will not fit, you need to get the adjustable engine mount by GPM. The picco will drop right in. I have a force 25 in my savage and its got a ton of power.
Old 04-08-2004, 09:57 PM
rclement
rclement's Avatar
I rechecked and you're right, the Picco lines up with the holes. The HPI motor mount needs some filing to fit but not a problem. Who carries GPM?
Old 04-08-2004, 10:32 PM
vizaracer
vizaracer's Avatar
i think www.hobbyetc.com carries GPM. they do. alot of GPM stuff. if you need the GPM site i can get it for you. i have it on my comp somewhere
Old 04-08-2004, 10:37 PM
rclement
rclement's Avatar
That would be great Vizaracer. You're awesome.
Old 04-08-2004, 10:51 PM
vizaracer
vizaracer's Avatar
heres the GPM site i think but when i type in www.gpmracing.com i come up with www.hobbyetc.com coming up. heres their site i think. http://www.gpmracing.com.hk/car/page/whatsnew.asp
Old 04-09-2004, 06:37 AM
doctorgoodwrench
doctorgoodwrench's Avatar
i have a force .25 in one of my trucks, i drilled and tapped the mount to make it work. $0 and 10 minutes later i was in business
Old 04-09-2004, 10:03 AM
Frost_
Frost_'s Avatar
ORIGINAL: doctorgoodwrench
Same here, and same here... [8D]
Old 04-09-2004, 10:36 AM
rclement
rclement's Avatar
That's a good plan. I'll do that..... Thanks.
Old 04-09-2004, 06:08 PM
Bobby26
I put the force 25 in my savage. But i noticed the throttle wasn't opening all the way. Do you have this problem? Even though the throttle wasn't opening up all the way it would have my tires ballooning up. CHEERS
Old 04-09-2004, 06:55 PM
doctorgoodwrench
you may have to lengthen the link between the carb and the swinger and play with your trim to get it to work, but it will
Old 04-09-2004, 09:32 PM
rclement
rclement's Avatar
I got the Force 26 to fit. I had to drill two extra holes in the engine flanges but it went together after that. That's as far as I've gotten for tonight. Can't wait to get this truck going and check it out. Thanks for the help. Rob
Old 04-09-2004, 11:22 PM
Bobby26
i have two savages one with the gpm guard and one without.. i notice the one with the gpm guard makes the tank go in more towards the engine.. should i try putting my 25 into the one without the guard on it?
