JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
speed sensor
Old 08-01-2002, 10:14 PM
kelly vallee
Default speed sensor
Does anyone know how to set up the speed sensor for only max speed setting. I have one and I'm going to set it up, but the only thing I want is the max speed. Do I have to calibrate the sensor. Kelly
Old 08-03-2002, 02:53 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Hi Kelly,
You just install the sensor per the instructions and plug it in.
MAX LIMITAIRSPD (in the limits menu) is always active, just change that value to whatever you want and you are in business
If you are using 2 channel mode, then do the following,
In the limits menu, set
SPDCTRL SW0 ACT to DISABLED/NONE
and then set
If you are using one channel mode you don't have to do this.
As for calibration, you can do it if you want it is not mandatory.
Sorry for the delay in answering.
